difference between hp style and mls cometic head gasket????
Old Aug 9, 2003 | 08:14 PM
EK_vzla's Avatar
Default difference between hp style and mls cometic head gasket????
difference please!!!! i hace this moment cometic mls 75.5 m 0.30 i want to put in my civic whit 8psi this work or only work hp style for turbo??
Old Aug 9, 2003 | 08:36 PM
EK_vzla's Avatar
Default Re: difference between hp style and mls cometic head gasket???? (ARAXIS)
ttt
Old Aug 9, 2003 | 10:44 PM
Boostfed's Avatar
New User
The HP gasket has a Fire ring for boosted apps instead of using copper or stainless steel orings . The HP is usually thicker starting at .043inch HP=High Pressure
Old Aug 10, 2003 | 05:57 AM
EK_vzla's Avatar
work or not??
Old Aug 10, 2003 | 11:10 AM
Boostfed's Avatar
New User
Default Re: (ARAXIS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARAXIS &raquo;</TD></TR><TR><TD CLASS="quote">work or not??</TD></TR></TABLE>
Many many people swear by them others are into stock gaskets, can't go wrong either way IMO. We have had good luck with Cometic HP gaskets locally on alot of stock sleeved blocks.
Old Aug 10, 2003 | 07:14 PM
EK_vzla's Avatar
TTT........I NEED MORE INF
Old Oct 17, 2004 | 05:17 PM
bigedx's Avatar
i know this thread is old, but can someone shed some more info please
Old Oct 17, 2004 | 06:09 PM
JDogg's Avatar
Default Re: (bigedx)
as long as it tuned and built right either one will work fine
Old Oct 17, 2004 | 07:04 PM
PrettyLude's Avatar
just remember when you have orings not to use the hp, but if you don't have o-rings you can use it
Old Oct 18, 2004 | 07:25 AM
earl's Avatar
Default Re: (PrettyLude)
Stepped deck or O-rings, you must use the MLS.
If you have a normal flat deck, you can use the HP but if it were me, I would still use the MLS. I have not seen a lot of good feed back on the HP's. Anyone?
Old Oct 18, 2004 | 07:38 AM
Boostfed's Avatar
New User
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Stepped deck or O-rings, you must use the MLS.
If you have a normal flat deck, you can use the HP but if it were me, I would still use the MLS. I have not seen a lot of good feed back on the HP's. Anyone?</TD></TR></TABLE>
616whp 28psi running fine for me!
Old Oct 18, 2004 | 09:06 AM
JDogg's Avatar
Default Re: (Boostfed)
600odd hp with copper o-rings and ge sleeves... used mls and hp on that motor, no problems at all.
ls95hatch
Feb 4, 2004 02:38 PM
JFK78
Nov 24, 2003 12:26 AM
ludesleep
May 30, 2003 07:44 AM
93LSivic
May 12, 2003 04:35 PM
