Reuse a Cometic HP headgasket?
Old 11-21-2003, 08:45 PM
JFK78's Avatar
Default Reuse a Cometic HP headgasket?
Has anyone ever reused a Cometic HP headgasket? I swear I heard somewhere that they are reusable. I really don't want to have to pay for another one. Anyone?
Old 11-21-2003, 10:04 PM
rOby's Avatar
Default Re: Reuse a Cometic HP headgasket? (JFK78)
damn ur a stingy ****. ive heard the same tho
Old 11-22-2003, 12:27 AM
89dxhunchback's Avatar
Default Re: Reuse a Cometic HP headgasket? (rOby)
My friend has a 10sec buick GN and he runs them. He says they are "rebuildable". Like you send $20 to they with the HG and they recoat it... BUT that's for GN's... Prob. the same for honda too though..
Old 11-22-2003, 08:36 AM
earl's Avatar
Default Re: Reuse a Cometic HP headgasket? (89dxhunchback)
I have reused Cometic MLS's successfully in emergency situations. The raised areas in the gasket must still be raised to do this successfully, however. If the gasket is flat and looks used up, it could possibly fail. Use copper spray when doing that.
Old 11-22-2003, 08:07 PM
JFK78's Avatar
Default Re: Reuse a Cometic HP headgasket? (earl)
Thanks for the input. Since this is a HP gasket with the extra "fire-ring" around the cylinders, do you think it is more likely to seal if reused than a normal 3-layer MLS gasket?
Also, what does the copper spray accomplish?
Old 11-22-2003, 08:27 PM
Flamenco-T's Avatar
with gasket, you need to go by the block that you're using. For o-ringed block, get the non o-ringed gasket and vice versa. It will seal the cylinders but it will not seals the water and oil passage.
The copper gasket seals tiny hairline spaces in between head/block to the gasket. It prevents seepage of coolant leaking out the longblock. Coolant is very corrosive to aluminum and a tiny flow/channel can means disaster in the long run as it can warp your head/block.
stan
Old 11-22-2003, 09:57 PM
six sigma racing's Avatar
Default Re: Reuse a Cometic HP headgasket? (Flamenco-T)
ive reused every headgasket there is on the honda market.... stock, stock bored, cometics, etc you name ive reused it...you just have to know how to look at the gasket... you could tell when it starts warping its no good.. ive reused gaskets when swapping different heads to try just sprayed copper on it and your good to go.....if it a street car.. and you dont know how to swap heads yourself... DONT TRY THIS AT HOME KIDS
Old 11-23-2003, 08:07 AM
earl's Avatar
Default Re: Reuse a Cometic HP headgasket? (DTRFAB.COM)
I would not reuse the Cometic HP. Not sure how those rings reseal after being crushed.
Old 11-23-2003, 08:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I would not reuse the Cometic HP. Not sure how those rings reseal after being crushed.</TD></TR></TABLE>
i keep forgetting im in the Force Induction forum......yeah earl is right.. if your boosting too much listen to him. its different for us NA guys aint no o-ring no solid decks etc. less pressure to worry about...
Old 11-23-2003, 08:41 AM
99B16Si's Avatar
i wouldnt use a new cometic headgasket. 0 for 2 with those POS's
never had one problem with the factory headgasket tho. just my $.02
Old 11-23-2003, 09:42 AM
redline201's Avatar
Default Re: (99B16Si)
yeah i woundnt use a cometic headgasket period
re-use one???? not a chance
Old 11-23-2003, 01:17 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt use a new cometic headgasket. 0 for 2 with those POS's
never had one problem with the factory headgasket tho. just my $.02</TD></TR></TABLE>I guess the question is...when they failed, did a stock gasket cure the problem? I have had such good luck with them, I am surprised to hear about problems.
Old 11-23-2003, 09:38 PM
Default Re: (jz)
Its prob. a SCE copper HG from summit.
Old 11-24-2003, 12:26 AM
DTRFABulous.COM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTRFAB.COM &raquo;</TD></TR><TR><TD CLASS="quote">ive reused every headgasket there is on the honda market.... stock, stock bored, cometics, etc you name ive reused it...you just have to know how to look at the gasket... you could tell when it starts warping its no good.. ive reused gaskets when swapping different heads to try just sprayed copper on it and your good to go.....if it a street car.. and you dont know how to swap heads yourself... DONT TRY THIS AT HOME KIDS</TD></TR></TABLE>
hey danny, do you reuse *** gaskets?? you know, the thin sheet that you sit on when you take a crap in public bathrooms....LOL
if you can get a new gasket, dont use you're old one unless you have no choice...
journeyquest
09-03-2010 12:39 AM
petrv
04-15-2004 12:34 PM
Btothe3rdDegree
08-20-2003 06:26 PM
SpoolnG2
11-01-2002 07:35 AM
schwett
06-18-2002 06:22 AM
Quick Reply: Reuse a Cometic HP headgasket?
