Dial indicator question
Old Dec 25, 2006 | 10:36 AM
SOHCD16y8's Avatar
Default Dial indicator question
Hey guys, I was just wondering what type of dial indiactor stands you are using and where you are buying them from. I would like to get a flexible type to measure endplay and check the crank for roundness. All I seem to find is the fixed magnetic type meant for cylinder bores. Let me know what you gus use, thanks
Old Dec 25, 2006 | 10:53 AM
Finland's Avatar
I have a magnetic base. All you have to do is make a steel plate that you can bolt on to the block (since it's aluminum and non magnetic) temporarily, so you can still take your measurements.
Old Dec 25, 2006 | 11:18 AM
RC000E's Avatar
Default Re: (Mr. Helsinki)
Yeah, I have used both a magnetic base and a little custom setup that bolts down using the rods from a magnetic base. It's fairly simple if you just have some scrap to use for mounting. I am at work otherwise I'd post a pic of mine.
Old Dec 25, 2006 | 01:20 PM
SOHCD16y8's Avatar
Thanks for the info guys
bigjay1six1
Dec 7, 2007 02:47 PM
pnjbiboye
Apr 10, 2007 11:15 AM
trick_db
May 13, 2005 09:00 PM
Mr. Samurai
Jul 24, 2004 01:15 AM
98specDC2R
Mar 26, 2003 04:11 AM
