Deltagate wastegates......question please help
Old Feb 22, 2004 | 10:07 AM
EG*MonKEY's Avatar
Default Deltagate wastegates......question please help
right now im trying to setup for boost.........and have a local offer for a deltagate wastegate for 150 how good is the deltagate.......i heard they spike....whats up//?should i get that or buy a tial38mm?thanks
Old Feb 22, 2004 | 10:29 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Deltagate wastegates......question please help (EG*MonKEY)
The Deltagate is ****. If you're planning on doing anything approximating serious boost, you'll want to invest in a nicer one.
Old Feb 22, 2004 | 10:35 AM
Mad Cow's Avatar
Default Re: Deltagate wastegates......question please help (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">The Deltagate is ****. If you're planning on doing anything approximating serious boost, you'll want to invest in a nicer one.</TD></TR></TABLE>
Wrong. If you change out the fitting that comes on the side of it (approx cost is $.99) then it works flawlessly.
However, $150 is too much for a used one. Might as well get a used TiAL one for that price. I paid $88 shipped for my deltagate.
Old Feb 22, 2004 | 10:45 AM
Unceasing Measure
Default Re: Deltagate wastegates......question please help (MadCow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong. If you change out the fitting that comes on the side of it (approx cost is $.99) then it works flawlessly.</TD></TR></TABLE>
My bad. Let me rephrase that. "A stock Deltagate sucks wiener,". Regardless of any fixes you can do to it, I advocate the Innovative Minigate over any other street application wastegate.
Old Feb 22, 2004 | 01:12 PM
Kataku2K3's Avatar
We've had problems with the Delta II in the past (like when we first started playing with turbo motors ~3 years ago... Lane's motor was overboosting right and left and we had no clue what the problem was)... Then when Scott (CrazyCompression) and I pulled off his Delta II and discovered that we couldn't even make it dump (felt like a 19lbs spring when it was supposed to only be a 7lbs.) we swapped to a Tial and have been using them ever since... On a high boost setup they'd probably work fine... I just don't actually know since we haven't used the forever... Just my $0.02
Old Feb 24, 2004 | 06:07 AM
SpdRcrChk's Avatar
I beg to differ. Deltagate wastegate on my b/f's 240 boosting 15 pounds, making well over 310RWHP.....and not a problem in sight.
Old Feb 24, 2004 | 06:39 AM
TurboTony's Avatar
Default Re: Deltagate wastegates......question please help (SpdRcrChk)
Yea I don't have a problem with it either, but I hear more bad about it then good.
Old Feb 24, 2004 | 11:01 AM
EG*MonKEY's Avatar
Default Re: Deltagate wastegates......question please help (TurboTony)
thanks for the info guys....i went ahead and ordered a TIAL 38mm with a 7lb spring from no limit for 215 shipped wish me luck =0
Old Apr 22, 2004 | 01:12 AM
XDEep's Avatar
However, $150 is too much for a used one. Might as well get a used TiAL one for that price. I paid $88 shipped for my deltagate.</TD></TR></TABLE>
change fitting? what is wrong with it and what do you change it to?
anyone know what the length of the middle allen nut is?
Old Apr 22, 2004 | 04:56 AM
fjt's Avatar
fjt
Default Re: Deltagate wastegates......question please help (XDEep)
I got my "Deltagate" for 125 with all the springs..I later found that it is a Racegate and not the regular deltagate..So it should hold boost nicelly w/o boost creep problems.
Old Apr 22, 2004 | 05:11 PM
mademan2723's Avatar
what did u do to the fitting on the side of the deltagate wastegate&gt; just get a bigger one ?
Old Apr 22, 2004 | 05:22 PM
alpha's Avatar
A Deltagate will not go near my motor. I have witnessed this wastegate spike more than a couple times. The most recent was turbosi03's Deltagate spiking to 14lbs. His ringslands and sleeves were no good after this.
Old Apr 22, 2004 | 05:26 PM
b18Gooch's Avatar
My bad. Let me rephrase that. "A stock Deltagate sucks wiener,". Regardless of any fixes you can do to it, I advocate the Innovative Minigate over any other street application wastegate.</TD></TR></TABLE>
LMAO!
I have blown a GSR block because of the Deltagate: 20psi spike, I don't recommend it either. TiAL all the way!
Old Apr 22, 2004 | 06:01 PM
turbosi03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">A Deltagate will not go near my motor. I have witnessed this wastegate spike more than a couple times. The most recent was turbosi03's Deltagate spiking to 14lbs. His ringslands and sleeves were no good after this.</TD></TR></TABLE>
yep... although I did have the drag mani also
Old Apr 22, 2004 | 06:37 PM
Stewie's Avatar
Default Re: Deltagate wastegates......question please help (turbosi03)
I bought a drag kit and I'll be using a delta gate. I'm hoping uberdata boost cut option works flawlessly, which I heard it does.
Old Apr 22, 2004 | 11:28 PM
XDEep's Avatar
Default Re: Deltagate wastegates......question please help (Mac8008)
well i took mine apart and looked at the diaphragm. sure enough its worn out at the edges of the plates which sandwich the diaphragm. here are some things i would do to it
1. if not using a boost controller, run a line from the hole on the top to a clean place in the engine bay, or even put a filter on it. i would just plug it, but i dont know how it would affect performance. the point is to keep dirt out of the chamber to keep the diaphragm clean.
2. port the boost inlet hole a little from the inside. if the other guy meant a bigger fitting helps, then a porting would as well.
3. smooth the sandwich plates on the edges. they feel pretty smooth already, but thats where mine split. a dremel or file should work.
4. make sure when you tighten down the cover, the diaphragm is as even as possible, even it means boring out the pre-punched holes in it more. any uneven stretch will cause more stress on that edge. the splits on mine were opposite of eachother, say from 11 to 1 o'clock, and 7 to 5 o'clock.
well i hope that helps any of you that are stuck with it.
someone said they dont stock or sell the diaphragms anymore?
is there some other type of silicone nomex we can source elsewhere? the tial ones seem different, and 59bucks a pop. greddy's are 70$! they both probably include new sandwich plates..
anyone have disassembled pics of a tial? id really like to know how they improved on turbonetic's design. heres the tial replacment diaphragm:
Modified by XDEep at 12:39 AM 4/23/2004
Old Apr 23, 2004 | 05:44 AM
This One's Avatar
If you want to see a what a headache looks like..... deltagate
VTEC_PRODUCTION
Sep 10, 2007 08:45 PM
nicktagz
Sep 23, 2006 01:06 PM
srg
Aug 11, 2006 11:53 AM
Quickgti1.8t
Jul 29, 2006 09:35 PM
EJ8 GSR-T
Jul 11, 2006 07:32 AM
