Defi tach question...
Old Aug 4, 2002 | 08:24 PM
CheezeFrog's Avatar
Default Defi tach question...
st00pid just installed my Defi tach (nice install!) but it's acting a little weird. When I get up in the rev range (Into the "big sweep" revs -- It's one of those 5k-11k has a bigger sweep than 0k-5k RPMs) the needle jumps around a lot. It's not a smooth sweep up to redline. It rattles and jumps and causes my shiftlight to go off prematurely. Anybody else have this problem? Did I get a bum gauge, or might it just be something dumb like a bad ground somewhere?
Old Aug 4, 2002 | 08:49 PM
racecarpete's Avatar
Default Re: Defi tach question... (CheezeFrog)
i say check the wiring.
Old Aug 4, 2002 | 09:16 PM
Trigun's Avatar
Default Re: Defi tach question... (SilverCivic2k)
its the defi link tach right? did you set the number of cylinders on the control box?
Old Aug 4, 2002 | 09:48 PM
CheezeFrog's Avatar
Default Re: Defi tach question... (Trigun)
Yah! The DIP switches are configured to 4-cyl. I mean, it reads the small sweep range of RPM's ok. But it seems that the higher I rev it, the more the needle wants to jump around. Hmm maybe RF noise? argh...
Old Aug 5, 2002 | 07:22 AM
b18bturbo's Avatar
thats the worst guage to run for TACH.. it sucks major ****.. I could never get mine to work right as well. Finalyl swapped it out for the autometer with playback.
Old Aug 5, 2002 | 08:15 AM
CheezeFrog's Avatar
Default Re: Defi tach question... (b18bturbo)
What type of problems were you having with yours? I was thinking of selling my Defi's and getting the Blitz DC series gauges.
Old Aug 6, 2002 | 07:40 AM
CheezeFrog's Avatar
ttt anybody?
Old Aug 6, 2002 | 08:03 AM
b18bturbo's Avatar
The only problem i have is with there tachs. They jump like hell after 5k rpm the stepping motoro drive is what suppose to minimize that but its way jumpy
Old Aug 6, 2002 | 08:10 AM
CheezeFrog's Avatar
That's precisely teh same problem I'm seeing You mean it's supposed to do that?!? Mine is tapped into the blue tach wire near the extreme driver-side part of the firewall. I thought that's where yer supposed to pull the tach signal from? Yeesh, I might have to return this thing then.
[Modified by CheezeFrog, 9:13 AM 8/6/2002]
Old Aug 6, 2002 | 08:20 AM
b18bturbo's Avatar
i just kept mine located int he car just mounted an autometer with playback in there works great.
scamp91ex
Nov 8, 2009 08:02 PM
DejaVu88
Dec 13, 2007 08:20 PM
CimorelliCRX
14
Jul 2, 2005 02:25 PM
98civic4dr
Sep 26, 2004 12:05 AM
grlstockb18c1
Jun 20, 2003 09:11 AM
