Decided on a Turbo... what else. BUDGET!
I am purchasing the following turbo kit for 1,500
Garrett Hybrid T3/T4
3 inch chrome intercooler upper/lower pipes w/ HKS sequential blow-off valve fitting
3 inch exhaust down pipe
A'PEXi turbo timer
Greddy boost gauge
660cc fuel injectors
HKS external wastegate (not street legal in California) * Comptech fuel pressure
regulator
DRAG T3/T4 turbo manifold (fits HKS external wastegate)
Spearco front mount intercooler
O2 sensor housing
turbo return oil line (has to be used with turbo)
hose clamps
Fits all Honda/Acura B series: B16 B18 B20
*** can support up to 630whp ***
* under 400 miles on turbo
Everybody tells me I need an EMS, but they are very pricey, and after the turbo kit I only have 2500 left for other engine mods and suspension. I have the following in mind
8:1 Pistons
Skunk2 Cam Gears
AEM Fuel Rail
Walboro 255lb Fuel Pump
Honda Fuel Pressure Regulator
Skunk2 Coilovers OR Eibach Coilovers
Feedback is much appreachated!
A'PEXi turbo timer
Greddy boost gauge
regulator
O2 sensor housing
hose clamps
8:1 Pistons
Skunk2 Cam Gears
AEM Fuel Rail
8:1.... you're nuts. your off-boost throttle response and power is going to suck. if its a street car, don't even think about going less than 9:1. most people are running 9.5-10:1.
630 whp will never happen off that kit either... unless your drag mani decides to spike the hell out of you--- which it will
you are worried about EMS $$ but are ready to spend 300+ on rods, and 400 on pistsons... cam gears--- for what cams??? if you're using stock cams, you don't need aftermarket cam gears. theres more money for your ems....
frankly, id feel safer running stock internals and a hondata then a piston/rod package.
plus, 660cc injectors really can't be controlled by anything less....
y the hell would you run 8:1 that is nuts man you will have no i repeat NO bottom or off boost power what so ever.
Also pissed off sol why would you consider running 8:1 on a car if it isn't a street car if it is a race car i would run the highest compression i can get away with
on a stupid-boosted car... like 50+ psi on a gigantor turbo, its not uncommon to run as low as 6:1 compression. lower compression generall gives more "room" for the boosted air to fit into.
there was a huge thread on 10 vs 9 just a couple days ago... have a look.
Origin
Jun 3, 2013 10:27 PM
Origin
Southeast (Sales)
Apr 4, 2013 07:03 PM
Origin
Jul 10, 2011 01:59 AM
