Deceleration Air Flow Correction Question... AFC
On my afc, what should the throttle be set to under Dec Air- right now its at ****. What about the Ne1 and Ne2? they are both set to 10% right now.
my setup is t3/to4e at 7 psi on 94 teg LS
-ryan
Modified by tegasaurus at 6:17 PM 6/8/2003
-ryan
I believe these setting are for maf sensor equipped vehicles with open air BOVs. The settings compensate for lost air between shifts. I would like to know if it could help with the popping/backfiring when lifting off the gas in MAP equipped turbo vehicles tho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR »</TD></TR><TR><TD CLASS="quote">I believe these setting are for maf sensor equipped vehicles with open air BOVs. The settings compensate for lost air between shifts. </TD></TR></TABLE>
correct.
correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail »</TD></TR><TR><TD CLASS="quote">
correct. </TD></TR></TABLE>
that helped....
i read that much in the manual but im not sure what i should set it to to correct the backfire/popping i am experiencing also.
-ryan
that helped....
-ryan
UnderGroundConcepTS
Oct 27, 2004 10:36 AM
