DC full radiator with turbo?
Old May 9, 2010 | 12:10 AM
punxsk8r555's Avatar
Default DC full radiator with turbo?
i am putting my turbo on and plan on keeping my full size radiator and the turbo and manifold fits but should i run 2 fans on the front pulling air into the radiator and thats it? or should i put one or 2 on the front and still have one fan on back?
Old May 9, 2010 | 01:37 AM
95DC2GS-R's Avatar
Default Re: DC full radiator with turbo?
You only need one fan really... on my GSR I was running a Fluidyne full size rad and a 12" slim fan pulling air into the radiator, and I still had A/C and never had problems with the car getting hot, even in traffic with the A/C on
Old May 9, 2010 | 04:08 AM
IN VTEC's Avatar
Unless the cooling fan is running all the time or is switched with the ac system, the ac won't work when at a standstill. The ac condensor needs airflow to exchange heat.
Old May 9, 2010 | 05:08 AM
95DC2GS-R's Avatar
Mine was set to run all the time with a relay on ign power
Old May 9, 2010 | 12:55 PM
i dont have ac anymore. so should i just ran one fan on the front of the radiator? i rather it be in the front so it frees up some room in the bay
Old May 9, 2010 | 04:40 PM
LightningTeg's Avatar
Community Builder
I have a Full size with a SPAL 13" puller and another 12" pusher on the condenser itself.
Old May 9, 2010 | 08:51 PM
jeffnerette's Avatar
Is there any advantages to having the radiator fan pushing or pulling?
Old May 9, 2010 | 10:55 PM
your car stay cooled like that? i will either do that or just have 2 on the front pushing into the radiator
Old May 10, 2010 | 12:49 PM
IN VTEC's Avatar
Can you even fit a push fan in between the condensor and radiator core?
Old May 10, 2010 | 03:34 PM
single cam fan's Avatar
my buddy has a full radiator in his hatch with a sidewinder turbo manifold. Ill try to get some pics of it
Old May 10, 2010 | 03:51 PM
g2turbo's Avatar
I would run two pushers and call it a day. That worked wonders for me in a DA. Honestly, having the full-radiator means your fans probably won't run as much anyway. When they do it will be plenty. Just get good fans.
Old May 10, 2010 | 06:01 PM
i dont have a condensor it probably wont fit if you do
Old May 10, 2010 | 08:30 PM
Community Builder
I have a pusher on the condenser and the fan motor sticks out pretty far and causes the 3" thick intercooler to be out pretty far but its not bad.
cn_bb
Aug 9, 2012 11:00 AM
slimsclub
Mar 30, 2011 05:15 PM
AK94GSR
Jul 30, 2010 12:32 AM
808jdm_profileEG6
Oct 25, 2007 03:34 PM
00IntegrAllmotoR
Oct 22, 2005 02:14 PM
