daily driver registry
Let's start a list for the following (must be daily driver or qualify as worthy of such a title):
car
setup
whp
miles on the above setup
miles driven per day
how long it's been set up like this
I just want to see if the allmotor guys really able to play the "reliabilty" card...
car
setup
whp
I don't know about the "All-Mottor Boys" But I can play:
1997 teg GSR
fully built motor
T3/T04E (old Turbo)
over 12,000 miles on set-up
about 50 miles a day
Over 1 year
New Set-up has only been driven to the dyno and street tuning. Once winter is over back to daily my teg goes!!
1997 teg GSR
fully built motor
T3/T04E (old Turbo)
Over 1 year
2003 Kia Rio
stock motor
Airesearch T3 .48/.42 water-cooled and internally-wg'ed
~6 PSI
not dynoed
15,000 miles on setup,
50-100 miles a day
over 1 year
stock motor
~6 PSI
not dynoed
50-100 miles a day
over 1 year
2000 civic h/b
98 gsr motor
stock sleaves bored .020 over
ctr cams, itr valve train, portflow retainers
wiseco pistons/eagle rods
gt35r turbo set at 15psi boost
450 whp 283 wtq
60 miles per day
starting second year runing this set up
daly driver + dragster on the weekends
11.6 sec 1/4 mile @ 124.5 mph with slicks
12.9 sec 1/4 mile @ 122.7 mph with falken azenis
98 gsr motor
450 whp 283 wtq
60 miles per day
1994 Si Hatch
83MM GE GSR, 9:1, Eagle Rods, T3/T67, No A/C, but PS kept
Over 450 WHP on 18 psi + pump gas. I have an alcohol kit and i've run 25 psi on the pump ish with that, but I don't run that unless i'm on the M/T's because it doesn't hook
Little over 10K on the motor.
30-50 miles a day, lots of road trips.
I took it last weekend snowboarding, 10 hour drive each way, lots of boosting on the highway. My car is full interior with 2 12's, it's HEAVY, but it hauls ***.
Love your setup 98ctr, damn clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch »</TD></TR><TR><TD CLASS="quote">Love your setup 98ctr, damn clean
thanks.
</TD></TR></TABLE>thanks.
1997 Accord
f22b1
t3/to4E 8psi
124,000mi - 4,000 boosted
avg 20 miles a day. I really drive 200 miles everyweekend to and from school and then no driving durring the week. The accord takes the 200mile trips with alotta boosting and loves it.
f22b1
t3/to4E 8psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">Let's start a list for the following (must be daily driver or qualify as worthy of such a title):
car 2000 Civic Si
setup sfp mani, t3/to4e, .50 comp, .63 a/r, .57 trim, 9:1CR b16, CP pistons, eagle rods, gsr cams, 2.5-3" DP to full 3" exh.
whp 289whp, 200lb ft trq @10.5psi
miles on the above setup approx. 18K
miles driven per day 40 give or take 10
how long it's been set up like this July 2004
I just want to see if the allmotor guys really able to play the "reliabilty" card...</TD></TR></TABLE>
car 2000 Civic Si
car : 91 Civic SI
setup : LS/T (see sig)
whp : 300ish
miles on the above setup : 10k maybe
miles driven per day : easily 50
how long it's been set up like this : 3 days since my new tranny
it was built to run NIRA in the mid to late 90's, and I rescued it from a life of garage living.
and that's 35 mpg if I can keep my foot out of it...
whp : 300ish
car: 93 civic coupe
setup: Z6 turbo see sig
whp: around 200
Miles: 22,000
miles per day.. depends gets driver 500 every weekend when i am home.
Set up since like august or something.
30+ MPG
whp: around 200
Miles: 22,000
30+ MPG
94 Integra GSR
81mm sleeved b18c1 w/ JE pistons and Crower rods, sc61, inlinepro manifold, 1000 cc injectors
whp 535, 320trq
ran for almost 10k miles
miles per day: 20 miles per day.
maybe 20 miles to the gallon if lucky..
whp 535, 320trq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb »</TD></TR><TR><TD CLASS="quote">1997 Honda Civic Hatchback</TD></TR></TABLE>
u should chek out http://www.clubek.net/forums
car: 1999 Hatchback
setup: D16Y7, currently @ 10 PSI no tunning yet
whp: No dyno yet
miles on the above setup: SInce the build up and turbo install it has around 7-8k miles
miles driven per day: around 25-35 miles per day
how long it's been set up like this: approx 4 months
whp: No dyno yet
