DA integra B20 Turbo
Old Feb 25, 2005 | 11:40 AM
Robs_B18c's Avatar
Default DA integra B20 Turbo
Alright guys I just got my B20 turbo from the shop and it sound sweet!! Now I was wondering what 1/4 mile time should I expect, what is good for street and track boost, and how reliable is my set-up? HP gains? 2380lbs. Here go's.
B20b block
P8R Head
B16 Cable tranny
Skunk2 IM
CM Clutch and FW
T3/T4 B .50 a.r.
Blox Manifold
FMIC
Tial WG 7 psi
Tial BOV
MSD inline fuel pump
2.5 DP
2.25 exhaust
No cat
Modified by Robs_B20T at 5:22 PM 3/6/2005
Old Feb 25, 2005 | 01:30 PM
LSBOI's Avatar
Default Re: DA integra B20 Turbo (Robs_B20b)
man i cant wait to get mines out the shop just awaiting pipeing. it sounds like a nice setup cant wait to see pics should be good. do you plan on running higher boost later after you get tuned? and what engine management are you gonna use? what #'s do you expect?
Old Feb 25, 2005 | 03:41 PM
Tchleung's Avatar
that 2.25" will really choke you if you wanna make big numbers. same with stock B20 thin sleeves...
Old Feb 26, 2005 | 09:23 AM
Robs_B18c's Avatar
Default Re: (Tchleung)
As for engine management I'm running a stock ecu with a SAFC.
I will upgrade to 3 inch down pipe and 3 inch exhaust before summer.
The B20 sleeves will stay stock until it cracks. I only expect to run 11 psi Max when it's tuned
Old Feb 26, 2005 | 09:36 AM
BJOnewiper's Avatar
Default Re: (Robs_B20b)
I seen it!
It looks good. Can't wait until you're done breaking it in and I get to drive it.
Old Feb 26, 2005 | 09:47 AM
ace42004's Avatar
Default Re: (bjo)
what shop was it at??
Old Feb 26, 2005 | 09:51 AM
BJOnewiper's Avatar
Default Re: (ace42004)
He got it done at Beeyond Engineering.
[url=http://www.beeyond-engineering.com[/url]
Robs_B18c's Avatar
BEEYOND ENGINERRING
Old Feb 26, 2005 | 10:16 AM
Ef-er's Avatar
what rpm does ure setup start boosting and when u reach full boost?
looking into a very similiar setup, all i gotta get is the turbo (not totally sure which one im gettin yet)
Old Feb 26, 2005 | 11:03 AM
Robs_B18c's Avatar
I haven't played with it much but it starts spooling as soon as you give it a little gas and full boost is at 2800-3000
Old Feb 27, 2005 | 08:33 AM
BJOnewiper's Avatar
Bump fo pics. And some Chinese food. Damn Mongolians.
Old Feb 27, 2005 | 11:33 AM
ace42004's Avatar
Default Re: (Robs_B20T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robs_B20T &raquo;</TD></TR><TR><TD CLASS="quote">BEEYOND ENGINERRING</TD></TR></TABLE>
Thats cool..yeah i knew bee and henry and them for the longest time..im gonna have them tune my car when i get my turbo kit put on the car..so im guessing ur keeping the DA since u turbo it now..u got any dyno numbers
Old Feb 27, 2005 | 11:49 AM
Robs_B18c's Avatar
Yeah I'm keeping the DA now. No dyno times yet, but Bee should be getting his dyno soon if the landlord isn't a ********
Old Feb 28, 2005 | 12:40 PM
HxCforever's Avatar
beeyond installed my suspension that never gets used. good guys
Old Mar 2, 2005 | 09:23 AM
Robs_B18c's Avatar
Just got 400 miles on the turbo kit. It's time to take it to 7500
Old Mar 2, 2005 | 09:26 AM
HxCforever's Avatar
can i ride in it when you decide to take it to the limit
Old Mar 2, 2005 | 09:32 AM
VTC_CiViC's Avatar
Default Re: (dirtydreds)
for a boosted DA..
Old Mar 3, 2005 | 10:18 AM
Robs_B18c's Avatar
Default Re: (VTC_ohgodnotagain_CiViC)
Is 11 psi safe? Considering I have a stock ecu, stock b20, stock injector.
Old Mar 3, 2005 | 04:58 PM
BJOnewiper's Avatar
I say you keep it to 11 psi at the track or when I'm in the car.
Fuel managment is key.
Wasabi.
Old Mar 7, 2005 | 09:26 PM
HxCforever's Avatar
looks beautiful
Old Mar 7, 2005 | 09:43 PM
DENCIO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_ohgodnotagain_CiViC &raquo;</TD></TR><TR><TD CLASS="quote"> for a boosted DA..</TD></TR></TABLE>
Old Mar 8, 2005 | 01:54 AM
qwkteg125's Avatar
Default Re: (DENCIO)
car looks good the only thing i would change would be the placement of the fuel pump. from your pics, it looks like it is just zip-tied to some random line in your engine compartment.
oh and what did you do to get your car down to 2380lbs?
Old Mar 8, 2005 | 02:17 AM
s2kdre's Avatar
Default Re: (qwkteg125)
nice set up, but you're gonna need a stud kit for that manifold, eventually those bolts are gonna get loose.
Old Mar 8, 2005 | 06:19 AM
junkyard racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robs_B20T &raquo;</TD></TR><TR><TD CLASS="quote">Is 11 psi safe? Considering I have a stock ecu, stock b20, stock injector. </TD></TR></TABLE>
your fucked. stock ecu, and stock injectors. why? if you want that ecu chipped, let me know.
hopefully you dont **** it up to bad.
Old Mar 8, 2005 | 06:51 AM
juiced2ndgenteg's Avatar
I ran 13.5@112mph(shitty tires) with a similar setup in a DA. but mine was tuned w/550's and it was a b16.
