DA i/c piping question???
Old Dec 16, 2004 | 06:34 PM
guywitaDA's Avatar
Default DA i/c piping question???
Is it better to run the piping through the hole on the drivers side or cut a hole where the washer resivoir is..... where in the hell can i get piping ......
Old Dec 16, 2004 | 06:54 PM
LSVtechnologytur...'s Avatar
Default Re: DA i/c piping question??? (guywitaDA)
I think which ever way uses less pipe is the best, on my DA im going to use the backdoor style intercooler which will get rid of the whole drivers side set of pipe. are you looking to make your own or buy premade piping?
Old Dec 16, 2004 | 07:58 PM
aznballer's Avatar
there are no kits avaliable for the DA, u gotta make ur own and where the wiper fluid is good or u can get a intercooler with both piping coming out of the passenger side and that will work also
Old Dec 16, 2004 | 08:09 PM
Davep's Avatar
It depends, do you still have a/c? how big is your IC?
Old Dec 16, 2004 | 09:05 PM
DENCIO's Avatar
Default Re: DA i/c piping question??? (Davep)
here's how i ran mine..
https://honda-tech.com/zerothread?id=920944
Old Dec 17, 2004 | 01:02 PM
guywitaDA's Avatar
getting rid of the a/c the compressor locked up.. lol
Old Dec 17, 2004 | 01:46 PM
Ben Huynh's Avatar
We have the DA intercooler piping kit available:
http://www.importparts.com/sho...=2250
Let me know if you have any questions.
Old Dec 18, 2004 | 06:25 AM
Davep's Avatar
Here is how I did mine. The other side isn't hooked up in the pic but it goes right next to the radiator like the other side.
Old Dec 18, 2004 | 10:19 AM
PrettyLude's Avatar
i knew drag had to make a kit for the DA
Old Dec 19, 2004 | 08:24 PM
guywitaDA's Avatar
Default Re: (PrettyLude)
yeah im just not wanting to pay that much for a piping kit
Old Dec 19, 2004 | 08:50 PM
Tchleung's Avatar
the drag kit is the worse pipping kit ever. it goes all over the place off the turbo, then it goes to the passenger fender well up front. aboeve the itnerooler all the way tyo driver side. then into itnercooler then back aroudn thru passenger fender then to TB. No thanks
Old Dec 21, 2004 | 06:04 PM
guywitaDA's Avatar
Default Re: (Tchleung)
yeah and drags price for the piping.. dang.... anyone have anymore pics of there set up
Old Dec 21, 2004 | 06:09 PM
The Destroyer's Avatar
Default Re: (guywitaDA)
Go to JCWhitney.
Old Feb 12, 2005 | 06:05 PM
Default Re: (Vtaaak y0)
Which bends and how many did you guys use?
Old Feb 12, 2005 | 06:43 PM
D.Dappa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guywitaDA &raquo;</TD></TR><TR><TD CLASS="quote">yeah and drags price for the piping.. dang.... anyone have anymore pics of there set up</TD></TR></TABLE>
Hey check out g2ic.com as one DA owner to another it will help you fina lot of info you need if you are already a member go the site and search for "intercooler piping" the thread was started by by Siccgsr92 you will definitly get some ideas hope that helps. i dont think the search function is activated unles your a member try it i'm not sure.
Old Feb 12, 2005 | 07:47 PM
1.8EG-T's Avatar
Default Re: (D.Dappa)
I agree, I had the Drag DA kit and the piping just sucked, not knocking on IP as Ben is the man, but the drag piping could use a major overhaul.
Old Feb 13, 2005 | 12:58 AM
TRC's Avatar
TRC
i personally think if you run it through the washer res, then it would look cleaner. but if you dont care about how it looks, then find the shortest route. either way a boosted DA is a very beatuifull thing to see!
Old Feb 13, 2005 | 08:03 AM
Na-Spirit's Avatar
I ran mine through the hole on the drivers side...get yourself 7 90 degree bends and a 180 degree just incase you need a real curve....i used 7 90's total on my setup. you'll be forced to ditch your washer fluid and A/C though. Ive seen people keep the washer fluid but just got in the way for me.
Na-Spirit's Avatar
oh i got my pipes from kteller.com....search 2.5" mild, or whatever size your looking for.
Old Feb 13, 2005 | 09:51 AM
boostedDA's Avatar
Nick, you remember that muffler shop that I was telling you about? The one that's doing mine? Well, I got the first half done (from the TB to the intercooler) and it's clean as hell. We are doing the second half probably this Tuesday. He is welding the oil pan, bov flange, and all the piping for only like $60. You can't beat that and not have to use any extra couplers! Hit me up on AIM if you got any more questions.
Chris
Old Feb 13, 2005 | 10:15 AM
drift2004's Avatar
Default Re: (boostedDA)
just cut a hole in the chassis in between the ac it fits perfect u just have to move ur ac thing that is next to the bumper it will fit perfect. 2.5 inch pipe
95civlx
Jun 2, 2010 10:45 AM
joshcivic00
Welding / Fabrication
Jul 18, 2005 09:29 PM
forcedaccord95
May 13, 2005 08:19 PM
nate951
Feb 6, 2005 07:19 PM
VaporTrail
Jul 23, 2001 09:30 AM
