d16z6 turbo setup
Old Jul 2, 2003 | 09:47 AM
Ragezero76's Avatar
Default d16z6 turbo setup
I am about to buy a d16z6 complete swap for my EG and ill have the motor out to put a turbo on it. a friend is going to let me use his any stock parts i need from his 1991 awd turbo lazer....i know ill need a turbo manifold, where can i purchase one of these for a 14b? also what kind of managment will i need? im only going to run 4 or 5psi so far. the head on the d16z6 is milled to keep that in mind. if i have all the parts from the lazer what else will i need? any sites that people have found helpful on this subject mater? and im kinda on a budget but the opportunity to use his busted lazer arose so i thought why not. thanx
Old Jul 2, 2003 | 10:09 AM
Tomek's Avatar
Default Re: d16z6 turbo setup (Ragezero76)
4-5 psi wont work unless you modify the stock wastegate actuator which is set at about 7psi..or run a huge *** ic that will net such a pressure drop. You can do what I did and make a custom manifold or you can run a hf manifold with an adaptor plate for a 14b. Off the laser you may want the ic, the bov, the o2 housing(makes making the downpipe wayyyy easier), and the injectors. As far as fuel management, I run the afc hack tuned on a wideband and its been running awesome for me.
Old Jul 2, 2003 | 01:58 PM
Ragezero76's Avatar
Default Re: d16z6 turbo setup (AztecEJ)
so i would have to modify his stock wastegate...BOV? i can get what ever i need from the lazer, but what would i need to purchase then, like if i get his stock intercooler would i have to make all new piping for it to fit my car? and if so i could i juat as easily get a FMIC anf make pipes for it?
Old Jul 2, 2003 | 08:03 PM
Ragezero76's Avatar
bump
Old Jul 2, 2003 | 10:39 PM
Tomek's Avatar
Personally, I have't tried these methods I just run it at the set 7psi.. but you can run the wastegate actuator off another car thats set a little lower or you can modify the stock actuator arm by shortening it. If you get the Blow off valve just make sure you get the flange for it off of the car as well so you can weld it onto your new piping. Piping you can find at jcwhiteny they sell mandrel bends in various sizes.
Carbcivic
Apr 17, 2013 10:32 PM
king29
23
Nov 17, 2009 05:37 PM
JDMroyEG5turbo
Apr 15, 2006 08:29 AM
001020
44
Feb 10, 2004 07:39 AM
Hybrid
Feb 11, 2002 07:28 PM
