D16Y8 turbo question
Old Aug 26, 2007 | 06:45 AM
spotscivic's Avatar
Default D16Y8 turbo question
so im boosting my civic and i am getting tons of differnt comments from friends and people on the fuel system....now can anybody offer the most logical answer on what i need to do to the fuel system on a (stock internals D16y8 running at 7psi.) i have a 12:1 FMU and a walbro 255 laying around dont know if its what i truly need.. thanks guys
Old Aug 26, 2007 | 07:47 AM
niCastro's Avatar
Default Re: D16Y8 turbo question (spotscivic)
I'm really new to all of this but I use a FMU but some people on here have been warning me against that (with out offering me any alternative). It seems to be doing fine for me though, once or twice I've had the fuel cut out a little but then it gets right back on it. I bet I can fix it if I get bigger injectors.
Old Aug 26, 2007 | 09:29 AM
willyboyK20's Avatar
Get rid of the fmu. With the tuning solutions out nowadays an fmu should be only used in emergency situations.
You need to get a chipped p28 (w/cromepro) ecu from a 92-95 civic ex and a ob2-obd1 jumper harness.
Get some 450cc or 550cc injectors and some to tune it and your all set.
With that fmu you have no control over the fine tuning of the engine and that will cause to holes to magically appear in your block.
Old Aug 26, 2007 | 10:33 AM
spotscivic's Avatar
Default Re: D16Y8 turbo question (willyboyK20)
should i still use my 255 fuel pump?? or just a stay with stock
Old Aug 27, 2007 | 11:16 AM
mengy007's Avatar
I'm running a ZC/D16Y8 minime setup with Garret T3/T4 A/F .60 at 7psi externally gated with a TiAL 38mm. I have the DSM bluetop 450cc injectors, running stock D16A6 fuel rail, pressure regulator, pump. I had my ecu tuned and it runs pretty strong.
Old Aug 27, 2007 | 01:10 PM
spotscivic's Avatar
Default Re: D16Y8 turbo question (mengy007)
so should all i need is bigger injectors?? and will DSM injectors work on a D motor if they will work on a B. is ther a difference.??
Old Aug 27, 2007 | 01:39 PM
90sedan's Avatar
Use the walbro pump. The dsm 450's will work, they will be a little tight to get into the fuel rail, but boring out the o-rings will make them fit.
I'm running a sohc zc at 9psi on a .42/.48 with a walbro pump and dsm 450's chipped and tuned with crome and it runs very strong.
Old Aug 28, 2007 | 10:31 PM
civicb16eg's Avatar
Default Re: (90sedan)
where can i get a chipped p28 with cromepro? and whats the cost on these?
Old Aug 29, 2007 | 02:38 PM
niCastro's Avatar
Default Re: (civicb16eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg &raquo;</TD></TR><TR><TD CLASS="quote">where can i get a chipped p28 with cromepro? and whats the cost on these?</TD></TR></TABLE>
yeah I'm wondering the same thing because I've been using the fmu for a few weeks and first off even when I'm not boosting my gas milage has gone to hell and I also know it's not a really a legit set up.
Old Aug 29, 2007 | 02:46 PM
Default Re: (niCastro)
for all your tuning needs
http://www.xenocron.com/
Old Aug 29, 2007 | 03:14 PM
90sedan's Avatar
Default Re: (willyboyK20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyK20 &raquo;</TD></TR><TR><TD CLASS="quote">for all your tuning needs
http://www.xenocron.com/ </TD></TR></TABLE>
Or
jk-tuning. Either is a great choice.
https://honda-tech.com/zerothread?id=1460393
Stephen Werda
Apr 9, 2017 05:08 AM
evolutionglitch
Jan 19, 2007 09:55 PM
ityab0y
Jan 25, 2005 12:31 PM
RNPoo7
Apr 10, 2003 11:15 PM
flat-blk-HB
Feb 2, 2003 06:53 PM
