d16y8 map
Uh, anything any of us gave you would still be a basemap, and would probably be worse than what Phearable gave you. Take your car to a real tuner, and the next time you open the motor up, get rid of that low compression ****.
reason why im askin 4 a map is I live I lousiana no 1 tunes here ,in the past we went to tony at t1 but we cant afford a gtr yet, he wont tune Hondas no more unless it was a previous shop build. reason 4 the cheap rods and junk low comp pistons parts we already had, along with turbo and injectors, we have about $1200 in whole car, if it comes to it il take it to Alamo motorsports in texas don't know of anymore in dallas
Find a tuner. Take your car to that tuner. That's your only actual solution right now. No one here is going to be able to do that for you. No two motors are exactly the same, and what might work for someone else, might blow yours. If you want to risk it, get a basemap from one of the reputable companies and run on that. If you want to do it right, take it to a tuner. End of.
portenio78
Engine Management and Tuning
Mar 31, 2012 05:32 AM
