D16y7 head gasket help !!
Old Sep 20, 2011 | 06:17 AM
HPfreak's Avatar
Default D16y7 head gasket help !!
Hi guys im rebilding my D16 for A 400hp turbo setup and in looking to buy the comtique head gasket but my question is does the thickness change somthing ?
And is there a better head gasket for the price ?
Thanks for the info !!
Old Sep 20, 2011 | 12:36 PM
kbouchard1092's Avatar
Default Re: D16y7 head gasket help !!
OEM gasket!!.... i wouldnt mess with anything else...Ive had issues with Cometic in the past. Some people do and others don't. You can't go wrong with OEM.
If its overbored alot i would get a Golden eagle which in Essence is a OEM gasket bored out to the appropriate bore.
changing thickness can affect compression and possibly cam timing pending on how thick/thin it is from the OEM gasket. Adding thickness to a headgasket is not the right way to be trying to lower compression IMO. if youre expecting 400hp from a d seies im assuming you know that requires forged internals, and need of a big turbo to hit that # .
Old Sep 20, 2011 | 12:42 PM
Madmood's Avatar
OEM or Fel Pro MLS. Never gone wrong on me ever.
Old Sep 20, 2011 | 01:06 PM
HPfreak's Avatar
ok thanks boys !
and yes i have eagle rod and vitara piston
Old Sep 21, 2011 | 05:28 PM
HPfreak's Avatar
Up
Old Sep 23, 2011 | 08:47 AM
Mike Rotch's Avatar
oem gasket with arp head studs
maybe even a block gaurd
Old Sep 23, 2011 | 01:09 PM
HPfreak's Avatar
ok thanks !
and is a block gard worth it ?
Old Sep 23, 2011 | 04:53 PM
Autoworks's Avatar
OEM gasket always
jetspeedz
Apr 1, 2018 07:26 PM
Eghatchgsr8
Sep 19, 2014 02:24 PM
chasmataz
Jul 25, 2010 08:35 AM
Joeski99Si
Apr 22, 2009 09:57 PM
jarven093
Feb 27, 2007 03:23 PM
