D16y5 boosted w/ S300 question
I've read a bunch of articles and or threads about the Y5 and how it works.. But I didn't see anything that would answer my question.
My question is, If I boost a Y5 can I use S300 w/o any issues?
TIA
Shane
TIA
Shane
The only issue is the conversion harness when you use an obd1 S300'd ecu. Otherwise its just like a D16Y8 but with a different cam/lifters (uses the same head casting). You'll have to fiddle with the basemap, since it won't have the same ignition values as a D16Y8, since its VTEC-E. The HX should use the 4-wire O2, it was the VX that used the 5-wire - meaning no obvious issues with Hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">The only issue is the conversion harness when you use an obd1 S300'd ecu. Otherwise its just like a D16Y8 but with a different cam/lifters (uses the same head casting). You'll have to fiddle with the basemap, since it won't have the same ignition values as a D16Y8, since its VTEC-E. The HX should use the 4-wire O2, it was the VX that used the 5-wire - meaning no obvious issues with Hondata.</TD></TR></TABLE>
Ok cool so it shouldn't be a problem then... thanks
cr-rex88
Oct 22, 2014 11:17 AM
