d16a6 turbo
Old Oct 29, 2012 | 10:29 AM
golden nugget's Avatar
Icon2 d16a6 turbo
im new to honda tech im here to get any advice on building a 300hp d16a6 turbo in 90 civic hatchback. im defently getting eagle rods but undecided what pistons to run i was thinking of vitara piston or cp pistons any help will be great thanks how much hp can vitara piston hold untell melting or cracking
Old Oct 29, 2012 | 10:30 AM
Default Re: d16a6 turbo
i kno ther tons of threads on this but i wanna start my own and get advice from people who actualy expericed with vitara pistons
Old Oct 29, 2012 | 10:42 AM
JuggerNaut-CTR's Avatar
Have you tried going to d-series.org?
You'll probably get the best help there...
Old Oct 29, 2012 | 11:39 AM
no i havnt ill check them out right now. thanks
Old Oct 29, 2012 | 11:51 AM
do you any one with 300hp d16 non vtec
Old Oct 29, 2012 | 12:28 PM
wantboost's Avatar
Who is Mr Robot?
The problem with standard length rods and vitara pistons is that it drops the compression ratio to like 7.5 to 1 and it makes the car almost undrivable out of boost. Unless you get custom length rods you should just get off the shelf forged pistons like wiseco or CP.
Getting 300 out of a non Vtec D is going to be hard, you're more than likely going to need a cam and head work at the very least plus the built bottom end
Old Oct 29, 2012 | 12:31 PM
^ Not to knit pick bro...but vitara's in a stock d16a6 nets 7.1:1 <----stupid low compression
Old Oct 29, 2012 | 01:34 PM
KevinEF7's Avatar
Milling .040" quickly hikes that right up. And the car is completely driveable out of boost
Old Oct 29, 2012 | 02:41 PM
wow 7.5.1 yea thats super low i was shooting more like 8.5.1 and was told vitara and eagle rods will put me in that cp ratio. where can i purchase these custom rods? should i get eagle rods and cp piston and keep my stock cp ratio
Old Oct 29, 2012 | 02:42 PM
whats a good piston/rod combo to yield me to 8.5.1 cp ratio
Old Oct 29, 2012 | 02:49 PM
Block sohc zc
PISTONS- VITARA OR CP
RODS- golden eagle h beam
BLOCK GUARD- golden eagle
ACL race bearing kit
HEAD ZC NON VTEC
VALVE SPRINGS – supertech
RETAINERS- supertech
CAM- bisimoto 1.2 turbo cam
(3 amlge valve job)
Cometic head gasket
GASKET MATCH EVERY THING
FUEL SYTEM
255 walbro pump
INJECTORS 750CC
INTAKE MANIFOLD
SKUNK2 66mm tb
THERMOL GASKET golden eagle
COOLING SYSTEM
HALF SIZE aluminum radiator
MISHIMOTO hose kit( ebay)
DAILY 8PSI – 15PSI MAX
GOALS-300whp – 350whp
TUNE ON CHROME
CAN I MAKE 300WHP WITH THESE PARTS
Old Oct 29, 2012 | 02:52 PM
Charlie Moua's Avatar
Originally Posted by golden nugget
Block sohc zc
HEAD ZC NON VTEC
(3 amlge valve job)
Cometic head gasket
FUEL SYTEM
255 walbro pump
INJECTORS 750CC
INTAKE MANIFOLD
SKUNK2 66mm tb
COOLING SYSTEM
TUNE ON CHROME
what turbo son?
Old Oct 29, 2012 | 03:00 PM
ALMOST EVERY TUNNER I TALKED TO WHERE I LIVE SAYS VITARA/EAGLE RODS PUT MY AT 8.1.1 RATIO IM STUMPED
Old Oct 29, 2012 | 03:04 PM
IMTHINKING OF GARRETT T3/T4 57 TRIM FROM GO AUTOWORKS
Old Oct 29, 2012 | 03:21 PM
i'm not a fan of the vitar setup at all.
works but far from effecient.
the last d16a6 turbo guy i talked to had miniram 57trim + rods + 10.1cr pistons + cam and was at 270whp @ +15-17psi...
300whp on stg1 cam 57trim non vtec d series... sure possible but more easily done and on less boost with z6.
GL
Old Oct 29, 2012 | 03:28 PM
IM DOING THIS BUILD TO PROVE NON VTEC MOTOR CAN MAKE POWER WITH RIGHT LOVE AND TOUCH. I KNO IT CAN BE MADE EASIER WITH Z6 HEAD BUT WANNA BE DIFFERENT. WHAT PISTONS DO YOU RECOMMEND?
Old Oct 29, 2012 | 05:25 PM
I completely understand what you mean, trust me... i'm a big a6 fan but also a realist.
10.1cr wiseco + eagle rods will help
Old Oct 30, 2012 | 07:52 AM
07Jul
YCP 75mm Vitara Pistons & Custom Length Rods Combo D16
Introducing the YCP and custom length connecting rods combo for all D16 applications. We have combined these popular parts into a cost saving combo. This combination of specially selected parts has been proven to hold 500+ WHP.
These I-Beam connecting rods have been custom made to work in conjunction with the Vitara pistons. They increase compression to reduce the slow spool time associated with Vitara pistons and a stock length rod.
- Block notching required*
- ~8.5:1 compression depending on head.
- 600HP Rated.
- Includes ARP 2000 3/8” rod bolts & assembly lube.
- Use with Vitara pistons only.
The P2P0 YCP Vitara pistons are custom made with friction reducing Teflon™ skirt coating. YCP makes the Vitara pistons that set the high HP records. Others may claim they have a superior piston but YCP has been proven time and again.
- Stock 2.952” PM3 diameter
- Teflon™ piston skirt coating
- Includes NPR gas nitride N-51 treated rings
- High strength AC8A grade casting
- T-6 stress relieving heat treatment
- Full floating 9310 case hardened pins
Old Oct 30, 2012 | 09:01 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
I never understood why people go to lengths getting custom rods only to use CAST pistons.
If you are building the engine for 300+, do it properly.
Old Oct 30, 2012 | 10:18 AM
should i buy the cp pistons with eagle rods and keep my 9.1.1 ratio. i agreee forged rods with cast piston dosnt seem right but every one tells me vitara good for 400hp plus and there almost half the price but like you said do it properly. im shooting for 8.5.1 ratio if i use eagle rods what piston should i use?? PLEASE HELP ONE OTHER THING SHOULD I DO A GOLDEN EAGLE BLOCK GUARD OR THERE
NO POINT
Old Oct 30, 2012 | 01:56 PM
custom rods bring you to zero deck and the ycp vitara with eagle rods 8.1.1cp ratio
Old Oct 31, 2012 | 06:12 AM
scottdh20's Avatar
have you ever driven a eagle vitara motor?
didn't think so....dont spread false info
my eagle vitara does just fine out of boost, feels no different than a stock n/a d-series. danz on dso or on here i think his name was welfarepc or something like that ran 10's on his budget a6 more than doable on a stock head. eagle/vitara bottom end and a stock head with properly sized turbo(aka not ebay) and you will be just fine
http://www.rcautoworksstore.com/cut/...86c5e74306a05d
^^^^^click this link^^^^
Old Oct 31, 2012 | 07:22 AM
what will be my cp ratio with
custom rods and vitara pistons
eagle rods and vitara pistons
please help
Old Oct 31, 2012 | 07:43 AM
scottdh20's Avatar
click link i just posted, call bob....bob is the **** and will help you pick the right set-up to fit your needs
Old Oct 31, 2012 | 07:58 AM
ive never drove on eagle/vitara build what will my cp ratio be if i go this route eagle/vitara from speed factor. 480bucks
