D15 turbo questions?
Old Dec 8, 2006 | 12:26 PM
1000kg88hb's Avatar
Default D15 turbo questions?
these question would be for a D15 with better pistons and rods, a good intercooler and water cooled turbo.
How much boost can the cylinder walls hold up to? what cams would be good to use for a application lik this? what fuel system modification would be good for this application?
Old Dec 8, 2006 | 01:33 PM
RyanEJ8's Avatar
Default Re: D15 turbo questions? (1000kg88hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1000kg88hb &raquo;</TD></TR><TR><TD CLASS="quote">these question would be for a D15 with better pistons and rods, a good intercooler and water cooled turbo.
Water are your power goals? Also I would probably use just an oil cooled turbo. That's what I have on my D16.
Old Dec 10, 2006 | 04:13 PM
1000kg88hb's Avatar
I have power goal of 350-400 at crank and try to get at least 300 to the wheels.
Old Dec 11, 2006 | 06:48 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1000kg88hb &raquo;</TD></TR><TR><TD CLASS="quote">I have power goal of 350-400 at crank and try to get at least 300 to the wheels.
I have SRP pistons + Eagle Rods and Precision SC50 turbo and Precision intercooler and it works fine for those goals. I'm acutally going for more soon on race gas.
Old Dec 11, 2006 | 08:58 AM
HiProfile's Avatar
Assuming you don't mean d15b, then the delta cams would be good for a non-vtec head, otherwise a sohc vtec head works great with the zex 59300 (I think thats the larger ver.).
A good turbo would be any straigh-T3 version (50 or 60 trim would be the best), .48AR exhaust, stage 1 exhaust - assuming its the zex cam and a 1.6L sohc vtec motor/head. Otherwise with a 1.5L non-vtec head you'd need an s-trim (54trim) t3/t04B or a 50trim t3/t04E turbo, both with .48AR exhaust - stage 1 or 3.
Cheap, strong internals would be vitara pistons and tuner toyz rods with ACL bearings, mixed with OEM's as needed.
Strong, proven reliable internals would be wiseco/arias/cp pistons and eagle rods with OEM bearings.
Depending on the turbo, the sleeves can handle a lot of power - more than a handful here have pushed 400whp on OEM sleeves. As long as the tuner knows D-series motors and isn't that agressive with the tune. Many tuners go by MBT power, and never check for detonation - which can lead to big problems if any smaller ones already exist.
Old Dec 11, 2006 | 09:01 AM
rextec's Avatar
only rods available for the usdm d15 are from crower and $600-700 a set. just get a 1.6 block.
Old Dec 11, 2006 | 02:50 PM
1000kg88hb's Avatar
The motor I have to work with is a d15b2 cause igot it for free out of a friends crx. I am going to find a multi point injection manifold and get a Zdyne ecu other then the Ecu the rest of the project is on a budget.
Old Dec 11, 2006 | 02:58 PM
1000kg88hb's Avatar
Has anyone here had their rebuilt short block done by laskey racing they have a pretty go deal on their rebulids for a d series.
check it out
http://www.laskeyracing.com/shop/dseries.htm
Old Dec 11, 2006 | 03:03 PM
nonvtecD's Avatar
Don't pay ridiculous money on building a D15 when it will be way more expensive than a D16 and have less potential. Get a D16 block for $100 and build that if you must build something. Otherwise just turbo the stock block and get some experience which it sounds like you need.
Old Dec 11, 2006 | 08:12 PM
rextec's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Don't pay ridiculous money on building a D15 when it will be way more expensive than a D16 and have less potential. Get a D16 block for $100 and build that if you must build something. Otherwise just turbo the stock block and get some experience which it sounds like you need.</TD></TR></TABLE>
AMEN!
sonny0330
Oct 3, 2007 08:52 PM
BOOSTD4dR
Mar 14, 2007 05:04 AM
Jedi Jake
Feb 20, 2007 06:40 PM
darkcrx
30
Apr 6, 2004 05:28 AM
slimbo
Jan 26, 2004 06:27 AM
