d series turbo?
Old Jul 8, 2005 | 03:14 PM
KURUPTinc's Avatar
Default d series turbo?
Looking to boost a d series. what motor is good to run a turbo on and how much boost is normal? answers will be helpfull thanks
Old Jul 8, 2005 | 03:16 PM
1boostedcivic's Avatar
Default Re: d series turbo? (KURUPTinc)
garrett t3 60 trim 48 ar.
14b
15g
Old Jul 9, 2005 | 12:38 PM
Street Ghost's Avatar
Default Re: d series turbo? (Das Bar 2k4)
I'm boosted with a Garrett .60/.48 T3 on a D16Z6.
Old Jul 9, 2005 | 12:41 PM
Elite Hatch's Avatar
Default Re: d series turbo? (Street Ghost)
How much boost can they take with proper fuel/timing managment on a stock motor.
Old Jul 9, 2005 | 12:54 PM
Das Bar 2k4's Avatar
Default Re: d series turbo? (1boostedcivic)
I used a z6/b7 on my project i need to get it tuned soon but i also used the apexi kit. But good luck on your build mang.
But for a stock motor the Z6 and Y8 are the best i think.
Old Jul 9, 2005 | 01:14 PM
Default Re: d series turbo? (Elite Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elite Hatch &raquo;</TD></TR><TR><TD CLASS="quote">How much boost can they take with proper fuel/timing managment on a stock motor.</TD></TR></TABLE>
how ever much boost it takes to yield about 200whp on a stock internal motor.
Old Jul 9, 2005 | 01:17 PM
YiNYaNg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street Ghost &raquo;</TD></TR><TR><TD CLASS="quote">
how ever much boost it takes to yield about 200whp on a stock internal motor.</TD></TR></TABLE>
For the turbos listed above you can get 200whp with about 10psi
Old Jul 9, 2005 | 03:06 PM
Default Re: d series turbo? (H-T)
i'm puttin 200 to the ground at about 7psi. smaller turbos will require higher boost levels.
Old Jul 9, 2005 | 04:01 PM
Machine1's Avatar
I'm running 15 psi with a small T3 and turboedit. No power numbers, only track times.
Old Jul 9, 2005 | 07:10 PM
tehboo's Avatar
On stock internals?
Old Jul 9, 2005 | 08:24 PM
SOHCmaster's Avatar
10psi and 35shot on stock internals here for the last 2 years D16Y8..Yes believe it.
Old Jul 10, 2005 | 01:58 AM
Calvinator's Avatar
Default Re: d series turbo? (Machine1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm running 15 psi with a small T3 and turboedit. No power numbers, only track times. </TD></TR></TABLE>
15psi on stock internals? How long have you been running this setup? and any 1/4 times? I see the 1/8 times on your sig
Old Jul 10, 2005 | 09:39 AM
Machine1's Avatar
Default Re: d series turbo? (xtremeazian)
It's a stock Y8 block/Y7 head with a Cometic headgasket and ARP studs.
The car was put together by us in June of 2004 and has been running 13+ lbs with an afc setup.
I recently got it back a couple months ago and switched it to TurboEdit and adjusted the boost a little.
1/4 mile times will be in August when the track opens back up.
We're going to the 1/8th mile tonight to see if we can better the time.
d16z6EG
Apr 26, 2010 02:49 PM
ekbaby
Aug 20, 2008 08:05 PM
ex_ricer
11
Dec 5, 2007 12:56 AM
cliff666
Apr 15, 2006 09:38 PM
radmxracer72
Jul 19, 2005 11:05 AM
