d-series trans
Old Mar 18, 2009 | 08:21 PM
98h22's Avatar
Default d-series trans
what d series trans are you boosted guys running?my differential just went in mine and im not sure if i want to you my close ratio (ex) trans.
Old Mar 18, 2009 | 08:24 PM
oneoverwrx's Avatar
Default Re: d-series trans
planning on using my ex tranny for now. I might try some other stuff later.
Old Mar 18, 2009 | 08:29 PM
98h22's Avatar
is there a big difference in the gear ratios between the two? i already spin bad in 3rd gear i don't want to make it have less traction on the street.
Old Mar 18, 2009 | 08:36 PM
civicsi940's Avatar
i am running a y8 trans. held good so far
Old Mar 18, 2009 | 08:47 PM
98h22's Avatar
not worried about it breaking. i just dont want to have real close gear ratios, and have less traction on the street.
Old Mar 19, 2009 | 06:33 AM
oneoverwrx's Avatar
even with it being close ratio it is still not bad. It is just alot closer than the other d series trannies. Just use it and youll be fine.
Old Mar 19, 2009 | 08:19 AM
EARLdaSQUIRREL's Avatar
official honda whore
the ex trans has about the same ratios as a B series Ls transmission which is by far the longest gears
stick with the ex transmission or else you will just be slowing yourself down
if your having problems with traction get boost by gear and better tires
Nlarge
Oct 24, 2018 01:06 PM
TOM KREUTZBERG
Feb 13, 2014 04:04 PM
jdmshawn95
Feb 9, 2011 06:46 PM
jdmshawn95
Aug 1, 2010 02:51 PM
hmt_eg
Feb 15, 2008 06:48 PM
