Which D series motor mounts?
Old Oct 8, 2003 | 12:58 PM
Pfieff's Avatar
Default Which D series motor mounts?
Who makes a motor mount for the d series that has less vibration then the jim fab mounts? Thanks,
Pfieff
Old Oct 10, 2003 | 05:00 AM
Pfieff's Avatar
Default Re: Which D series motor mounts? (Pfieffdog)
Old Oct 10, 2003 | 05:06 AM
ELSpool's Avatar
Might want to try inserts, then tend to cause less vibrations, but keeping things pretty tight.
Old Oct 10, 2003 | 06:04 AM
Pfieff's Avatar
I heard of some people using ES inserts, any idea on where to pick them up?
Old Oct 10, 2003 | 06:11 AM
sporkcrx's Avatar
Default Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">I heard of some people using ES inserts, any idea on where to pick them up?</TD></TR></TABLE>
I have them. Picked em up at summitracing.com
turbohappy's Avatar
Go ghetto. Cut pieces off a polyurethane cutting board to shove in the cracks (I got mine for &lt;$1) and then fill the rest with 3M Windo-weld (~$10). DSM guys have been doing this for years with great results
Old Oct 10, 2003 | 07:31 AM
Pfieff's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">
I have them. Picked em up at summitracing.com</TD></TR></TABLE>
Do you like them? How much vibration compared to stock?
Old Oct 10, 2003 | 09:17 AM
beerbongskickass's Avatar
Motor mounts help eliminate wheel hop and "tighten" things up. They will make everything vibrate more so if you want it quiet use your stock motor mounts.
Old Oct 10, 2003 | 09:19 AM
Pfieff's Avatar
Default Re: Which D series motor mounts? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Motor mounts help eliminate wheel hop and "tighten" things up. They will make everything vibrate more so if you want it quiet use your stock motor mounts.</TD></TR></TABLE>
I just know that some cause more vibration then others. I heard that the jim fab's are the worst when it comes to vibration. I was just curious as to how much more vibration comes with the ES inserts
Old Oct 10, 2003 | 09:41 AM
sporkcrx's Avatar
There's a ton more vibration than stock. I noticed a huge difference in vibration and feel when I installed them, mostly because my stock mounts were ripped, so these are just a cheap fix for that. I'm totally used to the vibration now, but everyone who isn't thinks my car is about to blow up or die. But it was awesome being able to actually feel the engine, when you push it WOT and shift hard it's MUCH more clean. Felt sooo much better. Probably one of the best mods I did for $20.
Old Oct 10, 2003 | 09:45 AM
Pfieff's Avatar
Nice, I think i'll have to pick up a set. Thanks
c for sea
25
Jun 23, 2007 03:33 PM
2k3
Sep 18, 2006 10:23 AM
4NLINE UNLIMITED
18
Jun 16, 2005 03:33 PM
Sprayin_civic
Apr 13, 2004 10:00 AM
jaminonyourface
Oct 20, 2003 07:43 AM
