D Series on Boost. This Sound Doable?
Old Mar 2, 2006 | 05:24 AM
Power Rev Racing's Avatar
Default D Series on Boost. This Sound Doable?
I have a 91 EF Hatch. Right now I auto X the car. I am actually thinking about changing the car from a AutoX car into ao Drag car. The car weights 1790 lbs right now. I have a D16Y8 in the car right now.
Now since I am thinking about drag racing the car. I am thinking I will go boost. I have a set of weisco pistons 9:1 comp .20 over, and a set of eagle rods sitting under my bed. I am debating if I should ditch the D series or not. I want to make about 400 hp on boost and maybe run like a 75 shot of nitrous on top. I want to get to about 450 hp all together. I know for sure the head will have to get ported to hell to try and make that much HP. I was thinking about buying a Comp Cam also to help out the airflow.
Does this setup sound doable, and should this setup be able to get me into the low 11's with the right suspension setup and traction? With the car weighting in at under 1800 pounds still?
Old Mar 2, 2006 | 05:26 AM
VisualAutoMotoring's Avatar
Default Re: D Series on Boost. This Sound Doable? (Power Rev Racing)
Anything is do-able. You just got to find the right combination of parts.
Id put more emphasis on acheiving your whp on just boost. Dont do 2 forced inductions together. I mean you can but there really isnt a point when you can just get what you want from all boost.
Old Mar 2, 2006 | 06:01 AM
tgreaves's Avatar
Here is the thing.. I would say either use a stock d-series or build a b-series.. But then again you said that you already have the pistons and rods for you d-series so why not just build that and use it..
And if your turbo is matched correctly for your power range you arent going to need a 75 shot on top of the turbo.. If your turbo is too big than you might need the nitrous to spool it up but for your hp range you wonlt..
And on the calculations it takes about 300whp to hit low 11's in that weight of car.. So if you have 400whp and a good suspension setup it can be done..
Old Mar 2, 2006 | 06:03 AM
RA166E's Avatar
Very do-able I went 12.3@118mph making 288whp on BFG's
300whp should net a 11 second ET.
Old Mar 2, 2006 | 06:06 AM
fjt's Avatar
fjt
well..full race got 465 out of Pinks car on a stock sleeve block so the power goals are achievable just on boost..you just have to do the right combination of parts and have the budget.
Old Mar 2, 2006 | 06:39 AM
Default Re: (fjt)
I guess I will put it together and see how it turns out. Now the pistons are 9:1 compression. Should I lower the compression anymore with like a .050 or .060 head gasket. Or should I just run a .040 head gasket? I will run race gas on high boost settings. Getting race gas over here is not a issue.
Old Mar 2, 2006 | 06:46 AM
turboEGhatch's Avatar
Default Re: (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">I guess I will put it together and see how it turns out. Now the pistons are 9:1 compression. Should I lower the compression anymore with like a .050 or .060 head gasket. Or should I just run a .040 head gasket? I will run race gas on high boost settings. Getting race gas over here is not a issue.</TD></TR></TABLE>
You're not going to have any problems running lots of boost with 9:1 compression and race gas, I wouldn't go much/any lower.
Old Mar 2, 2006 | 08:40 AM
fjt's Avatar
fjt
9.1:1 should be okay for boost
Old Mar 2, 2006 | 10:20 AM
nerdsports's Avatar
from all the information ive read, it seems like one of things holding the d-series back is the head.
also find the right turbo for your setup.
btw, where do you get race gas from so easily? I'm located in Miami as well.
Old Mar 2, 2006 | 11:33 AM
Default Re: (nerdsports)
My job
We sell VP racing fuel
Old Mar 2, 2006 | 11:37 AM
SOHC_MShue's Avatar
If you want that power goal out of the d series you will need to focus on having a good flowing head and low back pressure. You will need a decent sized turbo and if you can get an equal length manifold. The d series heads flow terrible compared to the b series so you need to lower the back pressure for that kind of power. Also the zex 59300/comp cam is a great cam and will help you achieve your goals. I know it made a huge difference over the stock cam on my setup and i'm not even pushing near that kind of power.
Old Mar 2, 2006 | 12:56 PM
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">If you want that power goal out of the d series you will need to focus on having a good flowing head and low back pressure. You will need a decent sized turbo and if you can get an equal length manifold. The d series heads flow terrible compared to the b series so you need to lower the back pressure for that kind of power. Also the zex 59300/comp cam is a great cam and will help you achieve your goals. I know it made a huge difference over the stock cam on my setup and i'm not even pushing near that kind of power. </TD></TR></TABLE>
Thats the exact cam I am going to get. its actually the 105300 for the Y8, the 59300 is for the Z. Yeah i guess i will really need to get that head ported big. I just need to make sure it goes to the right people.
Old Mar 2, 2006 | 01:32 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">Thats the exact cam I am going to get. its actually the 105300 for the Y8, the 59300 is for the Z. Yeah i guess i will really need to get that head ported big. I just need to make sure it goes to the right people. </TD></TR></TABLE>
I actually used to run the 59300 in a y8 head. Just had to fiddle with the cam timing.
Old Mar 2, 2006 | 01:49 PM
I actually used to run the 59300 in a y8 head. Just had to fiddle with the cam timing. </TD></TR></TABLE>
Yeah thats the only thing thats different.
Old Mar 2, 2006 | 03:18 PM
beerbongskickass's Avatar
Built the head as much as you can, run a Zex 59500 cam, and get a gt30r turbo setup... Your goals should be a piece of cake in your light *** car.
Here's a good example of what that turbo will do on a D-series motor...
http://forums.evans-tuning.com...=3145
Old Mar 3, 2006 | 03:52 AM
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Built the head as much as you can, run a Zex 59500 cam, and get a gt30r turbo setup... Your goals should be a piece of cake in your light *** car.
http://forums.evans-tuning.com...=3145</TD></TR></TABLE>
What do you think would be a good exhaust manifold to get? Something that under $900
Old Mar 3, 2006 | 07:20 AM
BOOSTIN1's Avatar
spoolinperformance.com has some nice mani's
Old Mar 3, 2006 | 07:28 AM
I Have an STD's Avatar
wrenchin'
Default Re: (BOOSTIN1)
cc-fab.net, he'll build ya a ramhorn for just over $400
Old Mar 3, 2006 | 10:29 AM
Default Re: (I Have an STD)
I like the lovefab short equal length mani, it's like $700 I think.
Old Mar 3, 2006 | 06:28 PM
Everyones Hero's Avatar
CC-fab has his ramhorns for around $400. If you PM "head" &lt;- HT S/N, he does D-series head porting for $1200.
Old Mar 4, 2006 | 04:51 PM
I got a GT40 for a good price. So i bought it.
Would this turbo be to big? Its ball bearing.
Old Mar 4, 2006 | 04:52 PM
i will post pictures of it later
Old Mar 4, 2006 | 05:46 PM
Chip's Avatar
FWIW, Geoff made 790 WHP on a GT4088R, they're quite a large turbo.
I'm "only" running a GT35R on my D-series which is a good amount smaller than a GT40R, shooting for 200 WHP more than you want to make, and I feel my turbo might be on the large side.
Old Mar 5, 2006 | 02:00 PM
Default Re: D Series on Boost. This Sound Doable? (Chip)
Two pictures of the turbo. Its brand new
Old Mar 5, 2006 | 02:05 PM
Blanket Jackson's Avatar
Very nice turbo. Good luck with the setup.
