Custom Inlet Manifold
Old Mar 25, 2004 | 11:52 AM
ZoRG's Avatar
Default Custom Inlet Manifold
This is work in progress, it will be made out of Carbon Fiber.
Any opinions, critisism, help appreciated.
http://www.we-todd-did-racing....D.jpg
The Plenum Volume 3648792.63 mm3 +- 450mm Long
The Runner Volume 230185.86 mm3 +- 140mm long
Modified by ZoRG at 7:03 PM 3/28/2004
Old Mar 25, 2004 | 11:54 AM
b18bturbo's Avatar
Default Re: Custom Inlet Manifold (ZoRG)
looks nice similar design to the wilsons manifolds
Old Mar 25, 2004 | 12:00 PM
AVATAR's Avatar
Default Re: Custom Inlet Manifold (b18bturbo)
EXACTLY . . . and if you're making it outta CF I hope it doesnt share the same price tag. Good luck on it though
Old Mar 25, 2004 | 12:02 PM
b18bturbo's Avatar
Default Re: Custom Inlet Manifold (AVATAR)
if you do make it a good price then ill probably get one
Old Mar 25, 2004 | 12:04 PM
G
sh!t happens.
for a good price
Old Mar 25, 2004 | 12:05 PM
ZoRG's Avatar
Only thing I need to still find out is whether the plenum and runners are the correct sizes.
If it flows well how does $750 shipped to the US sound?
Old Mar 25, 2004 | 12:11 PM
FredoSP's Avatar
kinda looks like a toyota supra IM
Old Mar 25, 2004 | 12:13 PM
ZoRG's Avatar
Default Re: Custom Inlet Manifold (FredoSP)
The design is taken from the wilson, with a few changes. I have not seen the supra one you are talking about.
Old Mar 25, 2004 | 12:43 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoRG &raquo;</TD></TR><TR><TD CLASS="quote">The design is taken from the wilson, with a few changes. I have not seen the supra one you are talking about.</TD></TR></TABLE>
Maybe i can post some pics, it reminded me of it. I think that manifold looks awesome tho!
Old Mar 25, 2004 | 01:03 PM
ZoRG's Avatar
I have been able to work out that it should be most effective at 7000rpm-10500rpm. Maybe a bit high.
Old Mar 25, 2004 | 01:51 PM
*Boostwerks*'s Avatar
U sir have some kickass cad skills...
Old Mar 25, 2004 | 02:10 PM
BodyKits NW's Avatar
Default Re: (Bryson)
That's a expensive project. If you can sell a CF manifold for that cheap then to you.
Old Mar 25, 2004 | 03:37 PM
Full-Race Geoff's Avatar
what helmholtz resonance frequency did you decide to tune it to? I am interested in how close it would match our exhaust manifolds freqeuency.
Old Mar 25, 2004 | 06:12 PM
rtype11's Avatar
Default Re: Custom Inlet Manifold (Full-Race Geoff)
that crazy zigzag where the plenum meets runners looks like its gonna create really bad vortexes, plenum volume in the 2,3 runner area is to large, what giggler pin did you use to calibrate with a 93-4 you shouldd stick with the 84v.1? IMO
oh yeah sorry to be a total ***, but if that is to scale that manifold will rest on my lap while driving.
Old Mar 25, 2004 | 07:31 PM
boostismycrack's Avatar
E-thug
Default Re: Custom Inlet Manifold (rtype11)
yeah, I think the wobbler shaft is too close to the angle of the dangle. What the hell are u guys talking about? Am I the only dumbass reading this post who feels retarded now?
Old Mar 25, 2004 | 07:33 PM
vtec.dc2's Avatar
make it out of composite plastic! it will be cost efficient and will help with heatsoak.
Old Mar 25, 2004 | 07:43 PM
Alchemist's Avatar
what program is that?
Old Mar 25, 2004 | 10:04 PM
ZoRG's Avatar
Default Re: (Alchemist)
Geoff I will get back to you on that, I am not 100% sure yet my calcs are accurate(New territorry, and waiting for Jeff to help me out), and there are a few changes that will happen fairly soon.
rtype11, I will look into your suggestions,but it will fit though, of course im still playing with it.
vtec.dc2 the problem with plastics are that you will need to make a few thousand units as the tooling will be super expensive. CF also helps with heatsoak.
Alchemist I use Solid Edge V15.
Old Mar 25, 2004 | 10:41 PM
15psi of fun's Avatar
Default Re: Custom Inlet Manifold (boostismycrack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostismycrack &raquo;</TD></TR><TR><TD CLASS="quote">yeah, I think the wobbler shaft is too close to the angle of the dangle. What the hell are u guys talking about? Am I the only dumbass reading this post who feels retarded now?</TD></TR></TABLE>
that **** is funny
it looks cool
it dose look like a supra intake manifold that i have seen
Old Mar 25, 2004 | 11:02 PM
ATS*Mark's Avatar
OG triple OG
bahahahhahahah i love it
and yes you are the only one
Old Mar 25, 2004 | 11:23 PM
Nid Styles's Avatar
From this picture the top cylinder will run lean with that runner being so flush with the very end of the velocity path. You need to stagger them in a stepped pattern where the first one the air will come into contact with when it enters the plenum is the longest with that design. Unless, you start playing with runner diameters. Changing the runner diameters raises the cost factor, and you'd have to figure out the flow rates, and the exact diameter that will match them. That would be a nightmare trying to find middle ground.
I need to start proof-reading my typing.
Modified by Nid Styles at 4:22 AM 3/26/2004
Old Mar 26, 2004 | 12:02 AM
ZoRG's Avatar
Default Re: Custom Inlet Manifold (Nid Styles)
I will be making some changes to the plenum soon, check this spot
Old Mar 28, 2004 | 09:59 AM
ZoRG's Avatar
Update. Still working on it.
BTW: Why DOES the wilson manifold make power? I have been grilled on why it should not make power, so far no explanation as to why it does.
Old Mar 28, 2004 | 10:25 AM
ZoRG's Avatar
One more update:
Old Mar 28, 2004 | 02:21 PM
88CRXHybrid's Avatar
the bellhorns shrowded by the flat walls on the bottom and the sides is going to hurt flow and increase turbulance. If you are wanting to use a raised bellhorn design you will probably want to look into raising them off the floor of the plenum. The other option would be to sink the bellhorns into the plenum floor but then you will need to fix the sharp walls and corners in front of and on the sides of the bellhorn.
