Current A/F ratio is too high
Old Dec 31, 2002 | 04:46 AM
Tony Starks's Avatar
Default Current A/F ratio is too high
D16Y8@7 psi, 12:1 FMU, MSD Inline pump, 270 cc injectors. Right now my A/F ratio is like 14-15 under boost. How can I bring it down to like 12-13? I assume by dropping my idle fuel pressure. Am I correct?
Old Dec 31, 2002 | 05:10 AM
g2turbo's Avatar
Default Re: Current A/F ratio is too high (Tony Starks)
14:1 is way lean under boost. what are you using to measure your a/f ratios. lowering fuel pressure would definitely not be good. by lowering your pressure it would be even leaner. Less base pressure = less total pressure under boost therefore leaner. more pressure more fuel you get the point.
if the car is running good and you are going of your a/f autometer then you want to see green on the guage. i see it hard for your car to be leaning out that bad unless something is not hooked up properly.
HTH
chris
[Modified by g2turbo, 2:11 PM 12/31/2002]
Old Dec 31, 2002 | 05:11 AM
Default Re: Current A/F ratio is too high (g2turbo)
My autometer POS shows green, but my apexi TT's a/f gauge shows 14-15. Should I increase fuel pressure?
Old Dec 31, 2002 | 07:09 AM
Old Dec 31, 2002 | 07:14 AM
lazy bum shaughn's Avatar
I heard that a/f guage isn't too accurate.
Old Dec 31, 2002 | 07:15 AM
austrian type-R's Avatar
take it to a real a/f wide band lambda meter
Old Dec 31, 2002 | 07:23 AM
VTC_CiViC's Avatar
Default Re: Current A/F ratio is too high (austrian type-R)
fuguman
Jan 20, 2003 12:48 PM
greyzone
Nov 18, 2002 07:02 PM
BorderM3
Nov 5, 2002 10:54 AM
JM Performance
Nov 28, 2001 03:46 PM
boosted97
Jul 8, 2001 04:50 PM
