Crossed over to the dark side - pics inside
Old Feb 14, 2003 | 09:55 PM
2000GSRT's Avatar
Default Crossed over to the dark side - pics inside
Rev Hard stage 2:
[Modified by 2000GSRT, 2:00 AM 2/15/2003]
[Modified by 2000GSRT, 2:01 AM 2/15/2003]
[Modified by 2000GSRT, 2:16 AM 2/15/2003]
[Modified by 2000GSRT, 11:06 AM 2/15/2003]
Old Feb 14, 2003 | 09:58 PM
Midwestrider's Avatar
Default Re: Crossed over to the dark side - pics inside (2000GSRT)
Red X's
Old Feb 14, 2003 | 09:59 PM
2000GSRT's Avatar
Default Re: Crossed over to the dark side - pics inside (Midwestrider)
Damn, sorry they aren't showing up. Let me try again.
Old Feb 14, 2003 | 11:03 PM
J.R.'s Avatar
cool, how does it run?? Are you using the fmu + inline?
Old Feb 15, 2003 | 07:11 AM
2000GSRT's Avatar
Default Re: Crossed over to the dark side - pics inside (96b18c1vic)
It's runs pretty good considering it's running on an untuned hondata map and a 2 1/4" exhaust so once I get those taken care of, I'm sure it will run even better. This setup is making more power at 6psi with the small exhaust than my JRSC setup did at 9psi.
Old Feb 15, 2003 | 07:36 AM
h82lose's Avatar
Nice setup did you dyno yet? Hows it running lean, rich?
Old Feb 15, 2003 | 07:38 AM
TurbothisLS's Avatar
looks good brotha, blitz bov looks
Old Feb 15, 2003 | 09:01 AM
2000GSRT's Avatar
Default Re: Crossed over to the dark side - pics inside (h82lose)
Not sure if it's running rich or lean I'm using a base map from another turbo car. but no detonation on the j&s =
That's actually a Vortech blow off valve
Old Feb 15, 2003 | 09:22 AM
boosted ls hatch's Avatar
hey i have a turbo ls with a drag gen III kit and im leaning out once i get under boost i have a walbro 255 fuel pump aem fuel pressure regulater and a vortec fmu can someone tell me what i need i put a fuel pressure gauge on it and im ideling at 90 to 95 psi so i dont know whats wrong i need to lower that but ill still have that problem i think
Old Feb 15, 2003 | 10:59 AM
Old Feb 15, 2003 | 12:05 PM
TurboedGSR's Avatar
Default Re: Crossed over to the dark side - pics inside (boosted ls hatch)
...i put a fuel pressure gauge on it and im ideling at 90 to 95 psi...
Old Feb 15, 2003 | 12:16 PM
94EGcoupe's Avatar
you must run more boost daniel son
Old Feb 15, 2003 | 12:36 PM
2000GSRT's Avatar
Default Re: Crossed over to the dark side - pics inside (90EFhatch)
Ahh yes, Mr. Miagi - I thought you might say that No boost for you!!!
Old Feb 15, 2003 | 12:56 PM
J.R.'s Avatar
I noticed You just put a filter and dont have the inlet pipe. I know the revhard kit doesnt come with one so I am probably going to do what you did for now. Does the filter slip off at all??
Old Feb 15, 2003 | 02:04 PM
DLB1994's Avatar
you have any whole PICS of your car
your a local guy to me then if you in Richmond
but theres allways a +for having a turbo gsr
[Modified by DLB1994, 11:08 PM 2/15/2003]
Old Feb 15, 2003 | 02:06 PM
2000GSRT's Avatar
Yeah, it was tough getting that filter to fit in. There actually is a pipe there but it's really short. I used a 3" 90 degree elbow and a 3" to 2.75" rubber coupling to attach it to the turbo. The radiator fan also had to be replaced with a thinner one because the turbo was too big, but it also made more room for the filter Hasn't slipped any.
Good luck.....
[Modified by 2000GSRT, 6:12 PM 2/15/2003]
Old Feb 15, 2003 | 02:13 PM
2000GSRT's Avatar
I'll have take some more pics of my car and post them. As soon as the weather clears up.
Old Feb 15, 2003 | 02:46 PM
SOHC_MShue's Avatar
hey i'm from Richmond
Old Feb 16, 2003 | 08:34 AM
94EGcoupe's Avatar
Ahhh must see pics of intercooler daniel son
Old Feb 16, 2003 | 08:46 AM
Diego Boost's Avatar
Nice placement of the yellow Neuspeed sticker, I have mine in exactly the same place.
Setup looks good btw.
MR. Klein
Jul 3, 2003 03:56 PM
BlkGSR
Acura TL, RL & ZDX
Feb 15, 2003 06:52 PM
