(crome) adding a switch to the ecu to nurn launch control on and off?
Old May 31, 2006 | 11:01 AM
RACEPAK's Avatar
Default (crome) adding a switch to the ecu to nurn launch control on and off?
hello everybody.
is it possible to add a swich that wired to the ecu to turn on\off the launch control? (crome)
thanks
Old May 31, 2006 | 12:45 PM
JonnyCoupe's Avatar
Default Re: (crome) adding a switch to the ecu to nurn launch control on and off? (RACEPAK)
My aircon seems to do the trick, with it on theres no launch control. So if you wire a switch up to that input you can have a switch for launch control.
Old May 31, 2006 | 12:46 PM
iBrandon's Avatar
You should to some massive research on http://www.pgmfi.org
To answer your question yes!
read up on it....
http://forum.pgmfi.org/viewtopic.php?t=7438
Old May 31, 2006 | 03:23 PM
Turbo_Mike's Avatar
Default Re: (crome) adding a switch to the ecu to nurn launch control on and off? (iBrandon)
Whats the point of doing that?
dewayne33us
Jan 31, 2010 10:19 AM
b20quang
Aug 22, 2008 03:15 PM
honda_joe
Jun 12, 2003 10:09 PM
