Critique my future setup!
Old Nov 24, 2003 | 06:13 PM
TurboJesse
Guest
Posts: n/a
Default Critique my future setup!
Pretty much got my setup for next year figured out but im still unsure about a few things...anyways let me know what you think...Flame on
Engine:
b16a
CP 9:1 pistons (also thinking about 8:5:1 JE's, i know some on here had them and made alot of power with a similar setup)
Eagle Rods (With arp bolts)
GE Block Guard
ACL Bearing rebuild kit
ARP headstuds
GSR Cams
Skunk 2 or JG Intake manifold w/hondata gasket (unsure between the 2)
Turbo Kit:
SS autochrome Modified manifold (i already have it and its been working great)
Tial 35mm wastegate (already have it, will the 35mm support 425whp?)
Precision SC61
3" custom DP
Precision 31x8x3.5 IC
DSM BOV (i have a Bling Bling JDM bov now, but i can't stand the noise and would prefer to sell it and use a crushed dsm bov, i have heard they can support alot of boost if crushed, any input?)
EMS: (already have everything on current setup)
Hondata s100b
720cc injectors
Walbro 255hp pump
Tranny:
Clutch (any ideas? running a CM stg. 3 now and i know that won't hold the powa)
LSD ...If i can afford it, otherwise it will wait..
Thats about it...looking for ~425whp
Old Nov 24, 2003 | 06:15 PM
Tinker219's Avatar
Default Re: Critique my future setup! (Mpir3)
if the wastegate location were a little better, I think the 35mm will support that. If I remember, you had a twin-inlets style correct? I think it might work pretty well.
the Cast SideWinder for example will support as much power as you can throw at it with a 35mm wastegate simply BECAUSE of the wastegate location.
Old Nov 24, 2003 | 06:16 PM
Jared's Avatar
Just a couple recommendations from my personal experience. Ditch the blockguard, you're better without one than with one, second, 9:1 pistons, 8:5 will be too low with just a 1.6, you wouldn't like the spool times on that 61, and last, not sure about how much your hp goal is or how much boost you plan on running, but get something other than the dsm bov for 20psi runs.
Old Nov 24, 2003 | 06:20 PM
TurboJesse
Guest
Posts: n/a
Default Re: Critique my future setup! (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">if the wastegate location were a little better, I think the 35mm will support that. If I remember, you had a twin-inlets style correct? I think it might work pretty well.
yea i put another outlet out the front of the collector (if you wanna call it one ) its been holding 1 bar with out creeping, etc..
Old Nov 24, 2003 | 06:23 PM
TurboJesse
Guest
Posts: n/a
Default Re: Critique my future setup! (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Just a couple recommendations from my personal experience. Ditch the blockguard, you're better without one than with one, second, 9:1 pistons, 8:5 will be too low with just a 1.6, you wouldn't like the spool times on that 61, and last, not sure about how much your hp goal is or how much boost you plan on running, but get something other than the dsm bov for 20psi runs.</TD></TR></TABLE>
Im kinda unsure about the whole blockguard thing too, i was just kinda following a setup that i think it was Jamal on here has, 8:5:1 stock sleeve b16a with an sc61 making 465whp...As for the bov im not sure how they work at high boost...I just can't stand my Bov now lol, way too loud...what about the metal bosch BOV's teh 996's run?
Old Nov 24, 2003 | 06:29 PM
t04ecvc's Avatar
The DSM BOV's are crap at higher rpm and boost levels, they start to leak. Just spend the 200 bucks and get a greddy, you will be happier in the long run.
Old Nov 24, 2003 | 06:48 PM
TurboJesse
Guest
Posts: n/a
Default Re: Critique my future setup! (t04ecvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04ecvc &raquo;</TD></TR><TR><TD CLASS="quote">The DSM BOV's are crap at higher rpm and boost levels, they start to leak. Just spend the 200 bucks and get a greddy, you will be happier in the long run.</TD></TR></TABLE>
Money isn't the issue, i have a Proft (sheepdog) BOV that is designed for extremely high HP now...i just can't stand the loud annoying sound of most BOV's, especially the greddy.
Old Nov 26, 2003 | 11:34 AM
Pfieff's Avatar
Jesse, you sure you don't want my greddy type-s BOV? I know you love the sound.
Old Nov 26, 2003 | 01:08 PM
bigwig's Avatar
forge BOV? they are good up to like 25psi or something and are pretty cheap. pretty quiet too since they are found on saabs...
Old Nov 26, 2003 | 01:11 PM
TurboJesse
Guest
Posts: n/a
Default Re: (bigwig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">forge BOV? they are good up to like 25psi or something and are pretty cheap. pretty quiet too since they are found on saabs...</TD></TR></TABLE>
My brother actually has one laying around my garage, i just remembered about it but i guess he gave it to one of his friends
Old Nov 26, 2003 | 01:14 PM
bigwig's Avatar
that sucks. just curious why you decided to go with the b16 instead of a B18...
Old Nov 26, 2003 | 01:25 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">that sucks. just curious why you decided to go with the b16 instead of a B18...</TD></TR></TABLE>
Ive had the b16 for awhile and just decided to keep it...I can make the power i want with it so theres no need to change it...If i had a heavier car (integra or EK coupe) i'd prolly want a b18 but my car barely weighs 2200lbs as it is..Im happy with my numbers now on the stock engine 307whp/212wtq, car is fast as fawk, just want more...like usual
Old Nov 28, 2003 | 06:27 PM
M.A.R.C.'s Avatar
Default Re: (Mpir3)
it's gonna be slooooooooooooooooooooooooooow
lol jesse. i think it should rock. btw... i ordered my sc61
Old Nov 28, 2003 | 08:41 PM
TurboJesse
Guest
Posts: n/a
Default Re: (CivicRyda2k)
and im picking up a b18c1 shortblock sunday How things change
Old Nov 28, 2003 | 10:43 PM
Drew Peacock's Avatar
Default Re: (Mpir3)
Why not get a a BOV that returns the air into the charge pipes Turbosmart do one I believe. I personally don't boost enough to get sick off the BOV sound...
MBlake55
Jul 30, 2007 01:34 PM
.adam.
Jul 28, 2005 06:58 PM
DFW
Feb 22, 2005 02:30 PM
TurboJesse
Nov 5, 2003 11:26 AM
MugenNSX
Oct 4, 2002 03:50 AM
