crazy torque!
Old Mar 8, 2006 | 06:24 AM
ham's Avatar
ham
Default crazy torque!
My setup has changed since (more boost) but I never posted my results.
This is a stock b18c1 with a SC61 (6.8psi) and a Precision AS1025 FMIC.
Blue is torque, Red is HP. Sorry for the crappy digital cam scan.
It IS possible to have matching TQ and HP on a honda motor! (236wtq, 240whp)
Old Mar 8, 2006 | 06:33 AM
Turbo_TONY's Avatar
Default Re: crazy torque! (ham)
awsome. way to go
Old Mar 8, 2006 | 06:45 AM
bluemax189's Avatar
Default Re: crazy torque! (Turbo_TONY)
people usually want torque the flatest possible, that way its consistant throught the powerband. but not bad numbers.
Old Mar 8, 2006 | 06:46 AM
Srr's Avatar
Srr
wow... that must feels lovely
Old Mar 8, 2006 | 06:53 AM
99B16Si's Avatar
interesting tq numbers
Old Mar 8, 2006 | 07:05 AM
mike1114's Avatar
Default Re: (99B16Si)
my setup is similar.
I have 311Whp @ 10psi and 300ft/lbs tq. B18C motor.
Old Mar 8, 2006 | 07:24 AM
TurboGSR96's Avatar
Default Re: (mike1114)
Thats a wierd looking graph you got there, HP never dropped off at all. Torque was all over the place, must feel nice driving that car around
Old Mar 8, 2006 | 07:29 AM
ham's Avatar
ham
Default Re: (TurboGSR96)
max rpm was only 7700. i always bounce off my rev limiter because i need a nice valvetrain to reach peak HP.
its in a crx too, with lensos... so hell yes its a blast to drive!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">my setup is similar.
I have 311Whp @ 10psi and 300ft/lbs tq. B18C motor.</TD></TR></TABLE>
Thats what i hope to get when i finish tuning for 10psi. might need some valve springs to rev up to peak hp though.
nonvtecD's Avatar
Stock GSRs can rev to at least 8200-8300 safely, torque shouldn't be as high as hp on a honda...
Old Mar 8, 2006 | 07:33 AM
MindEracer's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Stock GSRs can rev to at least 8200-8300 safely, torque shouldn't be as high as hp on a honda...</TD></TR></TABLE>
And the torque and the HP curve should cross at 5252!!!!
Modified by MindEracer at 9:44 AM 3/8/2006
Old Mar 8, 2006 | 07:36 AM
T3T495GSR's Avatar
Default Re: (MindEracer)
HOOOOOOLLLLY TORQUE
Old Mar 8, 2006 | 08:08 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindEracer &raquo;</TD></TR><TR><TD CLASS="quote">
you can see that in the pic? wow you have some good eyes
Old Mar 8, 2006 | 08:34 AM
urbansi's Avatar
Default Re: (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">
you can see that in the pic? wow you have some good eyes</TD></TR></TABLE>
In every dyno the hp meats the tq at 5252
Old Mar 8, 2006 | 08:44 AM
rextec's Avatar
Default Re: (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">
In every dyno the hp meats the tq at 5252</TD></TR></TABLE> i cant believe no one caught that sooner...
Old Mar 8, 2006 | 08:48 AM
TurboGSR96's Avatar
Default Re: (rextec)
I was thinking that, that graph looks like the motor was all over the place or the thing was possessed by something.
Old Mar 8, 2006 | 08:57 AM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">torque shouldn't be as high as hp on a honda...</TD></TR></TABLE>
Boosted Accords
Old Mar 8, 2006 | 09:14 AM
B18 CYA's Avatar
Hmm, thats really strange to see on low boost especially on an sc61
Old Mar 8, 2006 | 09:24 AM
LSTEG96's Avatar
this isnt always the case...its a feature on the dyno software called forced scaling...
this graph looks like mad boost creep doesnt it???
Old Mar 8, 2006 | 09:28 AM
ham's Avatar
ham
Default Re:
this isnt the final graph, so it does kinda go all over the place. you can see the A/F (black line) is all over the place (and below 11:1). The final was more smooth.
Old Mar 8, 2006 | 09:37 AM
Unsivil_audio's Avatar
Similar hp and torque figures indicate quite of a bit of exhaust restriction up top, known as reversion.
Given the formula HP=torqueXRPM/5252. I calculate you should have ~368whp with that kind of torque at 8200rpm.
Old Mar 8, 2006 | 09:47 AM
ham's Avatar
ham
Default Re: (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio &raquo;</TD></TR><TR><TD CLASS="quote">Similar hp and torque figures indicate quite of a bit of exhaust restriction up top, known as reversion.
Given the formula HP=torqueXRPM/5252. I calculate you should have ~368whp with that kind of torque at 8200rpm.</TD></TR></TABLE>
I only revved up to 7700 on the dyno, so I have more power waiting there. I thought you were supposed to use max tq rpm for the calculation... ?
HP=236X(5660)/5252 = 254.3
Old Mar 8, 2006 | 09:58 AM
mike1114's Avatar
Default Re: (ham)
where would my restriction be? I got a 3" downpipe and exhaust.
The only thing I can think of is the .48 turbine of my turbo, it may choke a bit up top but ITS A BLAST TO DRIVE DAILY!!! I used to have a .63 and I swapped it for more torqe and faster spool.
Old Mar 8, 2006 | 10:03 AM
Here's the way I look at it...you made what, 254whp@7900?
Since its a formula we can reverse engineer it.
Torque=HP*5252/rpm
Torque=254*5252/7900
Torque=168wtrq
168wtrq@7900rpm, that means you came down ~68wtrq in ~2200rpms (from 5660) and since hp is all about carrying torque into the higher rpms, and your torque is falling off so bad, your gonna see similar hp and torque #'s the higher you rev it.
Old Mar 8, 2006 | 10:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">where would my restriction be? I got a 3" downpipe and exhaust.
The only thing I can think of is the .48 turbine of my turbo, it may choke a bit up top but ITS A BLAST TO DRIVE DAILY!!! I used to have a .63 and I swapped it for more torqe and faster spool.</TD></TR></TABLE>
I would say the .48a/r is part of it, perhaps its your cams though. Thats probably what I would point my finger at right now on this guy's setup considering its a stock b18c1, also if he had revved it out he would've seen ~255whp.
Maybe someone a little bit more in the know will pipe in though.
Old Mar 8, 2006 | 10:25 AM
ham's Avatar
ham
ill post the final graph for 10psi (ill actually scan it) and we will see whats going on. Ill make sure we rev up to max rpm too.
Thanks for the info
