Crank battle
Old Apr 19, 2006 | 05:42 AM
teefunk01's Avatar
Default Crank battle
What crank is best to use in a b18b block? ..... would you guys rather go with b18b speces or b18c
Old Apr 19, 2006 | 10:31 AM
teefunk01's Avatar
Default Re: Crank battle (teefunk01)
bump
Old Apr 19, 2006 | 11:31 AM
adseguy's Avatar
wellllllll. You missed the biggest part of the question here.
<FONT SIZE="2">WHAT ARE YOU DOING WITH IT?</FONT>
rpms wanted?
power?
forged internals?
all motor? (looks like FI since you posted here, but you never know)
give us some deatils here. It's like asking what's better a dell or an IBM......give us some uses for it.
Old Apr 19, 2006 | 11:34 AM
Muckman's Avatar
Moderator in Chief
Default Re: Crank battle (adseguy)
IBM and LS
Old Apr 19, 2006 | 03:14 PM
boosted94cx's Avatar
* B A N N E D *
ls....why give up what little stroke you have when it's not going to gain ANYTHING
Old Apr 19, 2006 | 05:13 PM
adseguy's Avatar
Default Re: (boosted94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">ls....why give up what little stroke you have when it's not going to gain ANYTHING</TD></TR></TABLE>
You really shouldn't and can't rev that high with an LS crank and if you are using something like a GT40R turbo you'll need to rev to 9 or 9.5k rpm.
Old Apr 19, 2006 | 05:28 PM
dcturbols's Avatar
Default Re: (adseguy)
LS cranks can rev high just fine, just look at InlinePro and their drag cars, 700-900whp with ls cranks going past 10k rpm.
The stroke of most honda crankshafts are still small enough that they do not have any problems going to high rpms, but you will need to worry about side wall load, balancing, etc. because it can do a lot of damage if you don't put the correct components together
In reply to the original post, there really would be no point in putting in a smaller crankshaft, but all b-series cranks are interchangable. If you really want to choose the best invdividual crank for your engine (as in sorting through a bunch of b18b cranks) I beleive Endyn (www.theoldone.com) uses a method based on how well the journals match something on the block, basically taking Honda's OEM allowed tolerances and matching up cranks with blocks of same tolerance difference.
Modified by dcturbols at 6:44 PM 4/19/2006
Old Apr 19, 2006 | 06:20 PM
Muckman's Avatar
Moderator in Chief
You really think that 1.8mm longer stroke than GSR/ITR is going to make that much difference on rod/stroke ratio? Lots of ppl on this board rev to 9 grand with a LS crank, including me.
Old Apr 20, 2006 | 03:37 PM
* B A N N E D *
yes...ppl are still stupid in respect to r/s. i was gladly turning 92mm to 9500 daily with no worries
ITRiWISH
Feb 21, 2008 02:34 PM
ProjectBoosted
Oct 23, 2006 10:02 AM
1337 Si
Aug 8, 2005 06:28 AM
e jay one
27
Jun 6, 2005 11:36 PM
cygnusX1
Nov 10, 2004 01:02 PM
