Cracking/Rattle when i let off throttle?
hey, just finished turboing my b16a2. stock everything, only runnin 3.6psi to get it running and tuned. problem is when i accelerate and then let off from high revs there is a crackin/rattle noise coming the head. it does it when in neutral and stitting still. any one else had a similar problem??,
well kinda said it all ,but its only one cracking noise , sometimes 1-2 crackin sounds, doesnt sounds good , dont want to drive it. could there be slack in the cams or pulleys or belt ??.
Check valve clearances possibly?
Check your getting oil to your turbo? I had a simalar thing on my first turbo d16 setup it sounded awful it was just my t25 running without a good enough oil feed.
I cant think of much else, maybe do a compression/leakdown test to make sure or...
your catdaddy switch may not be terminating the harmonic value of the proprietary induction at the proper miles per gallon. check that, or the muffler may have a leaking main constrictor valve which is causing your wastegate to deregulate the wholesale fuel consumption causing a glitch in your transatlantic revolutionanary junction. hope that helps
