CP Ring Gap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">I went .018 top and .020 2nd </TD></TR></TABLE>
Same here
Earl actually recommended that I go with 17 and 19, but over-filing landed me at 18 and 20.
Same here
Quick question that I never really looked into....
When doing the oil expander rail, does it matter which way the 'gap' faces? Such as...
_/ \_ or __ __
I've always went by the ring diagram... but I've wondered if this makes a difference or not. Also, for the OEM rails/exp it recommends doing it 15 deg from the wrist pin for the bottom, 15 deg for the exp, and 15 for the top whereas the diagrams tell you to line the bottom up with the wrist pin location the exp gap 90deg and then the top at 180 from the first in line with the wrist pin location.
Just a little further info would be appreciated... I've never ran into problems the way I set them but it's always good to hear more info pertaining to this.
_/ \_ or __ __
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC1.8crx »</TD></TR><TR><TD CLASS="quote">Piston Ring End Gap
Bore Diameter/Naturally Aspirated & Forced Induction
75.50 mm / 0.011"
81.50 mm / 0.011-.012"
84.50 mm /0.012-0.013"
87.00 mm / 0.014-0.015"</TD></TR></TABLE>
i hope your builder is not building a turbo engine with those specs.....
75.50 mm / 0.011"
