Couple of ?'s W/Pics
Old Jun 3, 2004 | 02:55 PM
H.crx-si
Guest
Posts: n/a
Default Couple of ?'s W/Pics
Modified by H.crx-si at 8:53 PM 8/27/2005
Old Jun 3, 2004 | 02:58 PM
Vtec92Civic's Avatar
Default Re: Couple of ?'s W/Pics (H.crx-si)
isn't that a oil cooler?
Old Jun 3, 2004 | 03:00 PM
MachAF's Avatar
doesn't look like much of an intercooler... inlets like 1 inch.
looks more like an oil cooler to me.
Old Jun 3, 2004 | 03:04 PM
H.crx-si
Guest
Posts: n/a
Definatly not an oil cooler it's a air to air intercooler with 1.5 inch inlet and 1.5 inch outlet. She's a small little bitch though lol
Honda Hick's Avatar
That looks like a IC off of a MKI supercharged MR2.
Old Jun 3, 2004 | 03:06 PM
H.crx-si
Guest
Posts: n/a
I know what its off of if someone guesses they win a cookie haha
Old Jun 3, 2004 | 03:33 PM
5STAR3's Avatar
Default Re: (H.crx-si)
mazda 323
Old Jun 3, 2004 | 03:37 PM
H.crx-si
Guest
Posts: n/a
Nope think even smaller engine size lol
Old Jun 3, 2004 | 04:47 PM
model x's Avatar
firefly?
Old Jun 3, 2004 | 06:31 PM
boosted_dc2's Avatar
Default Re: (model x)
the turbo blades look to be touching the housing. if thats the case then you will be heading for disaster with that turbo.
Landon
Old Jun 3, 2004 | 06:38 PM
H.crx-si
Guest
Posts: n/a
Yup firefly hahaha
the turbo is close but dosnt touch I think it might when I really push on the side of it on the exhaust dp side but not on the turbo side. I figured once it's got oil in it and it's running that their isnt enough shaft play to worry about but maybe I'm wrong
Whats the worst thing that can happen if the turbine touches the housing? will metal peices be thrown into my throttle body and cause lots of engine damage?
Old Jun 3, 2004 | 06:40 PM
BSeriesTurbo's Avatar
no your mini-me intercooler will catch the pieces and save your engine.
Old Jun 3, 2004 | 06:43 PM
H.crx-si
Guest
Posts: n/a
Default Re: (BSeriesTurbo)
yay hahaha I knew that thing would come in handy
I think I'll just throw this **** on and hope for the best lol
The worse part so far is when I spin the turbine from both sides trying to forcefully move it back and forth I hear a *ding* sound every once in a while from the turbine touching......that cant be good.
Old Jun 3, 2004 | 07:26 PM
yea you dont want to use that turbo if it touches the housing. that will be spinning so fast if it hits when its runing it will shatter the wheel and will go in your motor.
Landon
Old Jun 3, 2004 | 07:38 PM
maxim's Avatar
Default Re: (boosted_dc2)
Ford Probe Turbo? I forget the year.
Old Jun 3, 2004 | 08:04 PM
Ri5e's Avatar
Default Re: (maxim)
that's an awfully small turbo
Old Jun 3, 2004 | 10:58 PM
Smokinsax's Avatar
The Boot
a lot of people dont even run an intercooler at 6psi...so something is better than nothing.
Old Jun 4, 2004 | 01:40 AM
H.crx-si
Guest
Posts: n/a
It only touches the housing if I force it very hard too. Once the turbo is lubricated with oil wouldn't it be fine though? Like the only way it will touch is if I put force on both sides of the turbine pushing the same direction and spin it.
Old Jun 4, 2004 | 02:59 AM
H.crx-si
Guest
Posts: n/a
Im thinking I'm gonna have to ditch this turbo and get another one. Does it matter how much force it takes to check for shaft play? I have to put quite a bit of force to show that shaft play in the turbine in the pics. When its oiled will that make a difference?
EJ8Squad919
Dec 22, 2012 11:36 PM
mac_24_seven
Mar 5, 2012 06:50 AM
ktek3
Aug 15, 2007 10:09 AM
maddog20
Jan 5, 2005 05:33 PM
mysss2k
Jan 5, 2005 12:33 PM
