couple ?'s bout going FI
Old Feb 17, 2006 | 12:41 AM
sohctodohc's Avatar
Default couple ?'s bout going FI
im looking to buy a greddy kit. and (i know its not the best but its something to start with) is it necessary to get a turbo timer and boost controller? and when drilling into the IM for vacuum how do you keep the metal shavings out of the IM? and what gauges would i need to keep track of everything so i know the car is running ok and what not??
Old Feb 17, 2006 | 12:55 AM
Rbehne2's Avatar
Default Re: couple ?'s bout going FI (sohctodohc)
t.timer-nice to have.
for this kit as being "something to start with" no boost controller right away.
DONT DRILL YOUR MANIFOLD!
you can find vac. from other places...like brake booster.
good guages might include boost, a/f, oil press/and temp.
Old Feb 17, 2006 | 07:09 AM
voltronR34's Avatar
No need to drill the mani. Get a vacuum block. Check out this link, and scroll down: http://www.jgstools.com/turbo/index2.html
A/F gauge is a waste of money UNLESS its a wideband o2 sensor/gague combo. And those are expensive. Don't worry about it unless you plan to do your tuning yourself on the street.
Good gauges to have are boost, and oil pressure. If you are taking your car to the track get water temp and oil temp as well.
Turbo timers are unnecessary. Nice, but all you have to do is drive chill for a min before you park the car, then let the car idle for a few seconds and everything should be fine. Because you are using high quality oil right?
Old Feb 17, 2006 | 12:34 PM
sohctodohc's Avatar
Default Re: couple ?'s bout going FI (voltronR34)
i use mobile synthetic. what am i suppose to be looking for on that website? im getting it tuned at a shop. wheres a goo place to send my ecu to get it chipped for hondata?
Old Feb 17, 2006 | 01:08 PM
voltronR34's Avatar
Scroll down to the VACUUM BLOCK is all I was trying to show you. Easier than drilling the manifold.
Old Feb 18, 2006 | 10:12 AM
sohctodohc's Avatar
haha either im retarded and cant find the VACCUM BLOCK or im blind cuz i dont see **** newhere on there.
Old Feb 18, 2006 | 12:47 PM
voltronR34's Avatar
Sorry I think I may have linked you to the wrong section.
Try this:
http://www.jgstools.com/turbo/ka24et.html
Old Feb 18, 2006 | 01:46 PM
sohctodohc's Avatar
so thats like je vacuum thing? i might not have the right manufacturer but if i by a better vaccum block there will be more fittings and enough vacuum to run all the extra stuff
Old Feb 18, 2006 | 03:16 PM
voltronR34's Avatar
I don't understand your question. Better vacuum block?
There will be enough vacuum to run what ever you want off that block.
BOOSTED AUTOMATIC SOHC
Mar 12, 2005 01:30 PM
JDM_EH2
Jul 16, 2004 10:56 AM
CivicMexicano
Nov 29, 2003 09:36 AM
Thrillhouse
Oct 29, 2003 06:19 AM
JM Performance
Sep 7, 2001 06:13 PM
