Couple Questions
Old Feb 12, 2007 | 12:17 PM
cvclover's Avatar
Default Couple Questions
Currently I only have a short ram and an Evo2 on my 99 Si... but once the turbo goes on, I would like an exhaust that looks and sounds more conservative. My power goals are around 260-270 whp.
Will having a 3'' downpipe to an Apexi WS2 hinder performance significantly? What if I had a KTeller 2.5''? I do not know what the KTeller 2.5 sounds like. I think a 3 inch system would be much too loud, correct?
Second, for fuel management, what is required to run an e-manage setup? OBD conversion? The e-manage doesn't seem to be used as much as I thought.
Third, on a motor with 124k miles, should I switch to Mobil 1 Synthetic?
Old Feb 12, 2007 | 02:06 PM
AWDstylez's Avatar
Default Re: Couple Questions (cvclover)
In the order you asked:
Yes, going from a bigger pipe to a smaller pipe is worse then just having a smaller pipe all the way through. I know from experience. Just get a 2.5" dp if you want to run a 2.5" exhaust.
No idea, I don't know Hondas or their engine management.
Yes, inspite of what many people say, it's never too late to switch. It's like a 40 year old saying it's too late to quit smoking. Just be prepared to fix a couple oil leaks.
Old Feb 12, 2007 | 05:19 PM
cvclover's Avatar
Default Re: Couple Questions (AWDstylez)
So all I have to do is put in some Mobil 1 Synthetic instead of my other oil for my next change?
Old Feb 12, 2007 | 06:05 PM
AWDstylez's Avatar
Yes.
Old Feb 13, 2007 | 09:27 PM
cvclover's Avatar
Ok, so I'm hearing that a 3'' exhaust creates better power gains... but I am worried about the sound output.
I find my NA Evo2 exhaust to be too loud and annoying... will a 3'' Kteller with a 14'' resonator be quieter? What about a 18'' resonator?
Modified by cvclover at 9:53 PM 2/14/2007
Modified by cvclover at 1:32 AM 2/16/2007
Old Feb 13, 2007 | 10:05 PM
APCforthewin's Avatar
18" ftw!
Old Feb 15, 2007 | 04:33 PM
cvclover's Avatar
Default Re: Couple Questions (APCforthewin)
Is that a serious answer? How will an 18'' resonator affect the sound vs the 14''?
What about performance?
deeweezy187
Feb 4, 2006 12:44 PM
lowgman
Welding / Fabrication
Jul 5, 2005 09:07 AM
zseeanz
Apr 22, 2005 12:51 PM
BlueShadow
Feb 14, 2005 12:34 PM
