couple of instalation questions
Old Oct 15, 2003 | 06:30 AM
arjusmc's Avatar
Default couple of instalation questions
why do some turbos have vacuum line hookups and some don't. is it for an internal wastegate/boost gauge?
and when replacing an oil pan gasket do are you supposed to put something like rtv sealent on it?
Old Oct 15, 2003 | 07:18 AM
highmilehatch's Avatar
Default Re: couple of instalation questions (arjusmc)
Some turbos that are not setup with an internal wastegate have a port on the compressor housing. As far as the oil pan gasket goes, there are four spots you are supposed to put rtv sealant. It's kind of hard to explain, but if you find a FSM online you can see for yourself. Torque them correctly and you are good to go.
eclypzex
Welding / Fabrication
Aug 14, 2009 11:59 PM
thudreem
Oct 20, 2006 08:43 AM
keebler65
Oct 4, 2002 08:40 AM
JMinSi2000
May 27, 2002 01:33 PM
yellowbulbs
Jul 17, 2001 01:12 PM
