Could this be a bad fuel pump
Ive been having some fuel problems. Running lean under boost. I just thought my injectors were hitting their max duty cyle since im using my b16 injectors on my LS-Vtec set up (just for break in purposes). But even not under boost it still leans out in the upper rpms (on the interstate). Also ive been running a holley intank pump for sometime now. When we first put it in a year ago, you could hear it as soon as you started the car. Now you cant even hear it at all. Thats why I think the pump is going bad. When we had it on my old turbo kit it did fine but the longer I had it the more quiet the pump got. Tomorrow im gonna change the fuel filter and see what it does, maybe ill get lucky and its just a clogged filter. Thanks any info will be appreciated.
Try unpluging the fuel pump..and pluging it back in again...Mines was kinda like that for a while..and i unplugged and plugged back the pump, and EVERYTHING was back to normal...it amazing..after all the headaches and suffering we go through trying to find out whats wrong, its always something you lease expect...and so simple.....
Ok I did a few more things today and no luck. First I re gapped the plugs some how they were gapped to big. Did that car quit spitting and sputtering under boost, but still ran lean . Next we changed fuel filters with a OEM one from honda. Still no luck ran lean once again. Next we started thinking that my home made check valves were causing it to run lean. So I borrowed my friends missing link and guess what, still ran lean. Ive been watching the air fuel and when you floor it it goes into rich until the turbo spools and once it begins spooling it drops into the lean. I even tried unplugging the fuel pump and hooking it back up. That didnt change anything. It looks like im gonna have to fork out the money and buy a new pump and try that out. The FMU seems to be working cause when u take the vacum line off and blow into it u can see the pressure rise a little bit. Well hopefully someone has an answer to my problem...........Thanks
So you are trying to run an FMU with an Intank pump!? ARE YOU CRAZY?
Why is that so crazy?
project dc2
Jun 8, 2008 08:05 AM
