copper intercooler piping
Old Jun 1, 2002 | 08:31 PM
bmm89's Avatar
Default copper intercooler piping
Any concerns with using copper tubing as intercooler piping???
I am mainly worried about corrosion, i know it's more expensive but have alot laying around...
Old Jun 1, 2002 | 08:43 PM
rice4life's Avatar
Default Re: copper intercooler piping (bmm89)
just spray paint it if you are worried about corrosion. copper is a very good heat absorbing alloy.
Old Jun 10, 2002 | 06:31 PM
Teg4e's Avatar
Copper doesn't corrode...it may turn green if acid hits it, i.e. the Statue of Liberty, but it won't hurt the strengnth of it. I'm not sure if it's easy to work with though for bending and what not.
edit: just spelling
[Modified by Teg4e, 10:32 PM 6/10/2002]
Old Jun 10, 2002 | 06:38 PM
92HB_HB's Avatar
i was gona use 2" copper tubing at home depot for my piping, but DAYEM!!! that shitznett is heavy!!, i'd rather stick with aluminized steel, not as heavy..
Old Jun 10, 2002 | 06:51 PM
falcongsr's Avatar
What is this crap?
Default Re: copper intercooler piping (92HB_HB)
copper isint cheap, is it? copper will turn green from oxidation, just from being exposed to air / moisture. pennies dont turn green cause they usually dont sit outside in the elements, cause they are nice and dry in your pocket.
Old Jun 10, 2002 | 07:10 PM
Giuseppe's Avatar
Default Re: copper intercooler piping (Teg4e)
wanna bet??
copper is a super SUPER conductor of heat, making it an ideal metal to cook with
but not the best thing for IC piping..WHY because it retains heat...
look at the expensive cooking pans, you'll see that the bottom parts are copper for this such reason...
so Copper for IC piping
Old Jun 10, 2002 | 08:19 PM
Teg4e's Avatar
Default Re: copper intercooler piping (Giuseppe)
Copper doesn't corrode...wanna bet??
Ok, but this didn't prove why they do or don't corrode....so why the ?
Old Jun 10, 2002 | 09:43 PM
Giuseppe's Avatar
the is for this statement.. made by yourself..
i didnt mean it in a bad way,
i dont like false statements.
Proof.??
http://aca.ninemsn.com.au/stories/684.asp
http://www.corrosionsource.com/techn...corrcopper.htm
and if u want to get really technical.
http://members.aol.com/logan20/voltaic.html
[Modified by Giuseppe, 1:45 AM 6/11/2002]
Old Jun 11, 2002 | 10:01 AM
Teg4e's Avatar
Ok, I'm wrong it does corrode, but only after a long time and/or under extreme circumstances. Your second link supports this:
The resistance of all grades of copper to atmospheric corrosion is good, hence their wide usage for roofing and for contact with most waters. The metal develops adherent protective coatings, initially of oxide, but subsequently thickening to give a familiar green patina on roofs and the dark brownish color of bronze statuary. Because copper is largely unaffected by potable water, its is widely used for tubes carrying domestic and industrial water.
Old Jun 11, 2002 | 10:24 AM
CovertFI's Avatar
well anyway. copper not good
Old Jun 11, 2002 | 10:39 AM
.nate's Avatar
Default Re: copper intercooler piping (CovertFI)
make the measurements for the IC piping, go to a muffler shop and get them to weld you your boost pies
Old Jun 11, 2002 | 10:51 AM
MoBlack's Avatar
New User
Actually, the reason copper is used in cookware is that it spreads the heat more evenly over a given area than steel or iron, due to it's molecular composition.
Also, it's a conductor, so by definition, it doesn't retain the heat, but it will take on/release heat VERY quickly. This means you'll see ~ the same intake temps, but sooner in the engines warm up cycle.
MoBlizack
Old Jun 11, 2002 | 07:58 PM
bmm89's Avatar
Default Re: copper intercooler piping (MoBlack)
this was a while ago, but ended up using a copper section, spray painted in and out as earlier suggested, heavier yes, but i have a bunch lying around and could braze sections together with mapp gas
copper does corrode, the pantina(green ****) is copper oxide that has been exposed to the air, but i have no clue weather it flakes off in intercooler pipes... still don't know, don't want to find out
Old Jun 11, 2002 | 10:08 PM
Mr. Thunderlips's Avatar
Default Re: copper intercooler piping (falconGSR)
Pennies don't turn green cause they're like .0001% copper.
Old Jun 12, 2002 | 12:09 AM
93LSivic's Avatar
Hmm, copper the new riceboy fad. Kinda like white wheels...
Old Jun 12, 2002 | 06:03 AM
CovertFI's Avatar
Default Re: copper intercooler piping (93LSivic)
whats wrong with white wheels?
Old Jun 12, 2002 | 04:13 PM
Giuseppe's Avatar
white wheels, thats an oxymoron...
no positives to white wheels..
cbstudd77
Nov 28, 2006 02:59 PM
93_teg_CT
Jun 2, 2006 11:51 PM
usdmcivic94
Mar 20, 2005 07:58 PM
Soon_2b_evil
Oct 12, 2003 03:04 PM
ID_ten_T
Aug 14, 2003 04:58 PM
