cooling problems will oil cooler help
i have a 92 hatch with a turbo ls. i have a 160 thermostat and thin fan running all the time, would an oil cooler help make it run cooler and is it worth putting on.
an oil cooler would help keep your oil tempratures down but not your coolant tempratures. I would modify your car to a full length radiator with one puller and one pusher fan if theres no room in front of the turbo. Also are you using a 50/50 mixture?
