cooling and fans
Old Aug 31, 2011 | 11:42 AM
  #26
sc34dc4's Avatar
Default Re: cooling and fans
Originally Posted by Turbo-LS
Oh well if its free then run it. I was under the assumption you were about to drop close to 200 bucks on a FAL so thats why i made that recomendation well plus the zirgo flws more air
Haha yeah he went to a K and full size rad so it's just layign around. I figure run it on the inside of the rad and my other 12" on the outside of the rad. Quick question on that also. Will this wiring setup make fan 2 come one when fan 1 does?
30- battery + with 30 amp inline fuse
85- chassis ground
86-power from oem fan plug
87- power wire of 2nd fan "or negative if pusher"
Old Aug 31, 2011 | 06:43 PM
  #27
Turbo-LS's Avatar
just wire the fans to the factory wire harness. i have my zirgo wired to the factory plug on the passenger side and my 12" pusher is wired to the factory connector on the driver side. both fans come on at the same time with a/c and rad control
Old Aug 31, 2011 | 10:22 PM
  #28
sc34dc4's Avatar
I'm not 100% sure if my factory ac wiring is still there. I know when I did the swap I did a wire tuck and got rid of some stuff. It should be but if not will my wiring of a relay do the same thing?
Old Aug 31, 2011 | 11:10 PM
  #29
jdmdomo's Avatar
sss
Old Sep 1, 2011 | 04:14 AM
  #30
Turbo-LS's Avatar
Ill be honest with you im not very good at wiring relays lol. Contact JZ98CTR on here. Thats my buddy Jay. He is the wire wiz. He actually wired my whold drag car back in the days
Old Mar 22, 2012 | 06:40 PM
  #31
CheLude NY's Avatar
Anyone here ever ran a oem del sol vtec b series radiator on a high hp turbo application? Some guy is sellin me one and he told me they're 1/2 sized and can handle high hp
Old Mar 22, 2012 | 06:44 PM
  #32
CheLude NY's Avatar
Didn't see how old this thread was
Old Mar 22, 2012 | 10:54 PM
  #33
racebum's Avatar
If your running a full sized radiator and your overheating you have other issues.
x2
i have that fat as **** koyo full size
never once have my fans came on
Old Mar 23, 2012 | 05:34 PM
  #34
sh!ft's Avatar
Who the fack changed my title?!
here is what i ended up doing
Old Apr 15, 2012 | 02:09 PM
  #35
g2turbo's Avatar
how does the new setup cool? Any overheating now?
Old Apr 15, 2012 | 05:08 PM
  #36
sh!ft's Avatar
Car has not been ran yet so I do not know.
Old Apr 15, 2012 | 08:51 PM
  #37
DelSolMarine's Avatar
A single 13" spal puller fan will cool more effective than a mishimoto shroud with generic slimfan on it...
the cost of just a spal puller fan alone is the cheapest and most effective cooling part for a turbo honda...
either will be sufficient though depending on the setup...
Old Apr 16, 2012 | 08:26 AM
  #38
bcumbie's Avatar
I'm looking into getting a better fan for my turbo gsr in a eg hatch. I currently have a fluidyne radiator with a generic slim fan in the push configuration. I'm wanting to run a pull configuration with a shroud. I've looked around a little and seem to keep coming across mishimoto setups. I'm just not sure what I should go with. The car is not a daily driver but I want it to be as reliable as possible.
Old Apr 16, 2012 | 09:58 AM
  #39
bcumbie's Avatar
I think I'm sold on the Spal 13" high performance puller fan.
DelSol-B18
Sep 12, 2012 02:54 PM
95LSS
Jul 24, 2006 06:35 PM
gsr4doorboostin
Mar 28, 2005 10:09 AM
