coolant spraying from overflow tank?
Old Oct 14, 2005 | 06:35 PM
zbaber's Avatar
Default coolant spraying from overflow tank?
ok. when im running the car pretty hard, coolant sprays from the overflow tank. its usually only under a good amount of boost it seems, but it only started to happen after i turbo'd it, and after i installed the 92-95 radiator
Old Oct 14, 2005 | 06:53 PM
slo blue's Avatar
Default Re: coolant spraying from overflow tank? (zbaber)
blown headgasket, cracked block, cracked head. do a leak down on every cylinder
Old Oct 14, 2005 | 08:55 PM
mike93eh
Guest
Posts: n/a
most likely headlift. under boost the head will lift ever so lightly and the pressure will go into the coolant passages. stock head bolts will stretch.
you will need arp headstuds, oem mls headgasket and copperspray to fix it.
st joseph, mo? wheres that? im in holts summit,mo
Old Oct 15, 2005 | 12:42 AM
zbaber's Avatar
Default Re: (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">most likely headlift. under boost the head will lift ever so lightly and the pressure will go into the coolant passages. stock head bolts will stretch.
st joseph, mo? wheres that? im in holts summit,mo</TD></TR></TABLE>
ya.. i thought about it being headlift.. a buddy of mine i think had this problem before... just realized that after i posted this.
i thought about doing headstuds, but im also thinking about ls/vtec this winter so i may wait on it... not sure though.. how does that copper spray work? i havent heard much about it..
oh and st. joe is about an hour north of kansas city
Old Oct 15, 2005 | 02:28 AM
91civicDXdude's Avatar
so im assuming the problem got worse when we fixed the charge pipes and it was boosting more?
Old Oct 15, 2005 | 10:31 PM
sir boostalot's Avatar
Default Re: (91civicDXdude)
im having the same problem
Old Oct 16, 2005 | 06:49 AM
zbaber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">so im assuming the problem got worse when we fixed the charge pipes and it was boosting more?</TD></TR></TABLE>
mitch, it only got worse..lol.. it runs ******* hard though... when i got home, i had coolant all over the pass. side of my window... im gonna check on some prices... if the headstuds arent to expensive i may just get some and put them in in the next few weeks.. if they are a little more than i thought, ill just wait on it and do it while im doing the ls/vtec.
jetspeedz
Feb 20, 2018 02:37 PM
aho
Dec 15, 2007 09:24 PM
blackeg
Mar 30, 2006 02:49 PM
tub_sephiroth
Jul 19, 2005 08:16 PM
ghettocrxsi
Oct 29, 2003 02:11 PM
