Converting T3/T4 .63 to .48?
Old May 14, 2003 | 11:22 AM
BoostedD15B7's Avatar
Default Converting T3/T4 .63 to .48?
Just wondering if anyone has converted their T3/t4 with a .63 ex to a .48? Is this possible or does it have to be sent away. Would i need a new shaft wth a ex wheel for .48? Or is just the housing different? Sorry if this is a stupid question...
FOrSfEd's Avatar
Default Re: Converting T3/T4 .63 to .48? (BoostedD15B7)
you can just swap turbo's with me, I have and .50 AR.
Old May 14, 2003 | 11:45 AM
Default Re: Converting T3/T4 .63 to .48? (FOrSfEd)
50 on the compressor? Im looking for a t3?t4 with a .48 exhaust housing instead of a .63...Looking for faster spool.
Old May 14, 2003 | 11:47 AM
Sonny's Avatar
You can just change the turbine housing as long as the new housing will accomodate your current turbine wheel. Ie, if you have a Stage 3 turbine wheel, you can't use a .48 a/r housing that was made for a Stage 1 wheel. It will not fit.
Sonny
Old May 14, 2003 | 11:49 AM
legendboy's Avatar
EDIT: Sonny beat me to it
It depends on what stage turbine wheel you have. I'm using a stock ford t3 cartrige with a t04b cold side. I just changed from a .48 to the .63 a/r housings with no problems. If your turbo uses something like a stage 5 turbine wheel then you need a housing designed for the stage 5 wheel. But they are interchangeable if they match.
Old May 14, 2003 | 03:20 PM
Default Re: Converting T3/T4 .63 to .48? (legendboy)
Cool. but how do i know what stage wheel i have....i have no clue.....its a Turbonetics T3/T4 for a sohc vtec delsol. I asked the guy i bought it from and he not sure what the specs are for it.
Old May 15, 2003 | 07:05 AM
anyone?
Old May 15, 2003 | 07:19 AM
swlabhot's Avatar
I would guess its a stage 3 wheel.
Cat'sturboteg
Jul 15, 2007 11:22 AM
BOOSTIN1
Feb 18, 2006 07:18 AM
underpressure02
Feb 10, 2004 07:26 AM
specie
Jan 15, 2003 06:15 PM
93LSivic
Jan 1, 2002 07:53 PM
