Compressor wheel nut -Keeps coming off
Old Feb 21, 2009 | 07:14 PM
bostdteg's Avatar
Icon3 Compressor wheel nut -Keeps coming off
Well this one has me a little baffled -
2 turbos same failure within 25 miles
Compressor nut comes off and catastrophic failure
setup - t3/t4
non intercooled
7 psi boost
stock LS
-3 an oil feed line
Nothing out of the ordinary
1st turbo was an e-bay one (assumed that was the problem)
2nd was a garett
1st one was took apart and shaft was blue and broken - sign of oil starvation
oil is feeding through line and seems fine, is it possible the 3an line is too small?
Has anyone else seen the compressor nut back off like this and what caused it?
need some help here dont want to toast another one
Old Feb 21, 2009 | 08:03 PM
TheShodan's Avatar
Moderator
Default Re: Compressor wheel nut -Keeps coming off
Not on a Garrett, especially since they are reverse-threaded. No one is molesting the turbocharger before installation are they? Are you sure there are no contaminates in the oil, or that the oil sending unit isn't obstructed in some way
Old Feb 21, 2009 | 08:13 PM
bostdteg's Avatar
both were reverse threaded - oil feed line seems fine - I usually put 4an lines on them with no restrictor - this customer supplied the lines and they were 3an - i am wondering if its not an oil problem and it it locking the turbine up at high speeds and causing it to spin the shaft in the compressor wheel - the garett was new out of the box too.
Thoughts - ideas????
Old Feb 21, 2009 | 09:17 PM
TheShodan's Avatar
Moderator
For Hondas, -3AN w/ no restrictor is fine. are I/C pipes poping off while driving at higher pressures? This is a leading cause of instant failure. It could also be that the engine is trying to save itself with his "high speeds" and is not getting oil to certain areas. The turbo will be first to be sacrificed. Make sure there is clean oil at the correct levels, the oil pump is operating correctly, and any oil relocation kits are circulating oil correctly. Sounds like something is wrong in this equation. Your oil system needs to be inspected.
On the turbo, ensure that no loctite or contaminants have entered the oil feed. Eliminate all oil feed line "filters", so that the oil is straight from the oil sending unit. Is this where the oil feed line is connected?
Old Feb 21, 2009 | 09:39 PM
bostdteg's Avatar
yeah its straight off the sending unit - Pipes are not blowing off holding around 7psi and wastegate is actuating properly. Its a non-intercooled setup so there is a sort run on the piping and the blowoff is working properly too. after cranking the engine over the feed line does not really flow very much oil volume (the 4 an ones i have done will dump a quart in no time) at starter rpms it barely would do a pimt in 30 sec (estimated) -seems very slow - oil pump is working fine everywhere else - honestly could it be a defective/too restrictive line. locking the turbine shaft down at high speeds and just letting the compressor wheel continue to spin thus spinning the nut off
This ones got me and i really am not sure - i am thinking about just putting the 4 an lines on it - i really dont want to kill another charger - there has to be a reason
Old Feb 21, 2009 | 10:17 PM
TheShodan's Avatar
Moderator
you'll kill the seals w/ a -4an line from too much oil pressure in the cartridge. what BOV are you using?
Old Feb 22, 2009 | 09:15 AM
bostdteg's Avatar
rfl
Old Feb 22, 2009 | 09:36 AM
Andr3w's Avatar
You to you think mabie his bov is tired of opening/closing all the time and at night unbolts it self and goes and beats Mr.turbo up ?
Old Feb 22, 2009 | 09:56 AM
Flashmn's Avatar
Sounds like it could be compressor surge that turns the compressor wheel on the shaft and thus the bolt manages to turn open and game over. I saw pictures of this happening to a turbocharger made in belarus...but that was running way more than 7psi boost.
Old Feb 22, 2009 | 10:02 AM
bostdteg's Avatar
I am going to check the wastegate internals out - any ideas?
Old Feb 22, 2009 | 03:53 PM
blinx9900's Avatar
Originally Posted by bostdteg
rfl
gtfo if your not going to help, nothing funny about this situation.
EDIT: nevermind i misread, sorry
wow, you clown on the one guy who is actually trying to help, i am sure you know more than shodan, so please, bless us with your interpretation of the problem.
Old Feb 22, 2009 | 04:04 PM
Tony the Tiger's Avatar
First question, are you drunk? Hahaha....
The guy you just told off, also happens to be the thread starter and is also the guy asking for help.
"rfl", is referring to the TurboXS RFL BOV... He was answering Shodan's question..... Just pointing that out for you; I knew it was a misunderstanding.
Old Feb 22, 2009 | 04:07 PM
blinx9900's Avatar
i am not but i think its better i say i am, i totally read that as rofl, reading owns me, thanks for pointing that out on me...
Old Feb 22, 2009 | 07:24 PM
TheShodan's Avatar
Moderator
I was actually trying to see if perhaps he was suffering from reversion as a result of compressor surge.
Old Feb 23, 2009 | 06:29 AM
bostdteg's Avatar
ok update:
Customer had supplied oil lines for this job. After inspection of everything and it looking ok - took line off again and took a closer look - i took a peice of plastic tubing typically used on boost gauges, the OD of it is .125" - thats -2an - it should slide right into a -3an with noooo problem - WRONG - it would go up to the crimp and stop - so i cut the line and the id of the hose is only about 3/32 inside - not even -2an.
with that being said tell me if this sounds correct:
at high speeds the shaft was locking up(due oil starvation) and the wheel kept turning enough to back the nut off - turbo 1 had the shaft broken too and it def was blued inside badly.
Opinions on this please.
Old Feb 23, 2009 | 07:10 AM
SovXietday's Avatar
That's because it is, 3AN line should move a quart of almost as quick as a 4AN would. I have a 3AN on my car. I had a loose fitting on the turbo, as in it didn't come completely off it just was no longer sealed. I drove across the street to a car meet and the car lost half a quart by the time I got over there.
What you're describing there is something clogged in there. It should be pouring a good amount of oil out of a 3AN line.
Old Feb 23, 2009 | 11:11 AM
bostdteg's Avatar
Looks like the oil line is the culprit - luckily this one didnt kill the garret it just spun off and that was it - i will inspect it and make sure its fine - anything else i should look for to possibly cause this situation?
oh - rfl - easily confused with rofl - i rofl'd when i read that - actually broke up some of the tension lol
Old Feb 23, 2009 | 01:02 PM
TheShodan's Avatar
Moderator
I would switch the line to a true -3AN SS line, and appropriately charge your customer the cost as opposed to just an inspection of the same crap lines.. This way the problem is actually solved, and your customer can concentrate on other areas of the car.
Rule of thumb. If a customer supplies parts that are not of typical standard for them, check these parts thoroughly prior to installation. That way you can help nip some of these problems in the bud, from the beginning.
Old Feb 23, 2009 | 06:12 PM
bostdteg's Avatar
Agreed - Customer has agreed it was his fault and paying the lines - i ate the labor cost just out of good nature - the oil line and fittings are swapped to our standad -3an size and driven for approx 50 miles problem free.
Yes Valuable lesson learned and thanks very much for all of the help/advice - everyone was very helpful on this!!
velisma
Jul 20, 2010 01:18 PM
bigbadboy
Apr 26, 2007 07:57 PM
Cyber ITR
Feb 10, 2007 08:44 AM
dome
Nov 15, 2005 02:18 AM
Acura_I-RS
Mar 9, 2003 09:59 PM
