compression test b16a low help
Old Sep 2, 2004 | 10:01 AM
mbdelsol's Avatar
Default compression test b16a low help
i have a b16a with 9:1 compresstion piston 84mm bore and eagle rods
just put the head on it. Wanted to do a compression check befor I put the motor in.
number came out 120,120,120,120
when add oil 120,120,150,150
any idea??
Old Sep 2, 2004 | 10:19 AM
mbdelsol's Avatar
Default Re: compression test b16a low help (mbdelsol)
could it be because engine is cold?? should i put the motor in? yes the trottle was open
Old Sep 2, 2004 | 12:54 PM
Honda Sport's Avatar
low numbers due to cold engine. proper warm up = proper compression numbers.
B16A Hatchback
Aug 22, 2008 09:25 PM
sohctodohc
13
Mar 7, 2007 05:53 PM
b16acrxer
Oct 19, 2003 02:43 PM
