compression ratio questions
Old Feb 8, 2003 | 07:30 PM
_Endless_'s Avatar
Default compression ratio questions
few weeks ago, i blew up my engine from running lean and boosting 9psi.
right now, my mechanic is suggesting that i swap to a lower compression piston like 9.5:1 or 10.0:1 from the stock 10.2:1 compression ratio so i could boost safely should i decide to boost 9psi again.
so here are my questions:
1.) if i put in 9.5:1 pistons in there, will it affect driveability and be noticeable? coz if i plan to sell the car in the future i don't intend to spend money again to bring the compression back to 10.2:1 but i'm afraid that the buyer might notice a difference in driveability. will there be a big difference between 9.5:1 and 10.2:1?
2.) what if i just drop it to only 10.0:1, will the 0.2 drop in compression be worth the money and have some advantage already?
3.) i plan to boost 7psi when my engine is finished and probably 9psi on occassion, should i still bother changing to lower compression piston or should i just stick to stock compression of 10.2:1?
by the way, i'm ditching my fmu and will be using the hack for fuel management. standalones would be nice but they cost too much.
any help will be appreciated.
Old Feb 8, 2003 | 07:38 PM
ekb18c's Avatar
Default Re: compression ratio questions (_Endless_)
If you use the hack and have it tuned properly you should be good at the stock compression 10.2:1 even at 9psi.
The fmu was the cause of your motors death.
Old Feb 8, 2003 | 07:39 PM
LsVTeCTuRBo17's Avatar
Default Re: compression ratio questions (ekb18c)
or mechanic was cause of death??
[Modified by LsVTeCTuRBo17, 8:39 PM 2/8/2003]
Old Feb 8, 2003 | 07:42 PM
ekb18c's Avatar
Default Re: compression ratio questions (LsVTeCTuRBo17)
[QUOTE]or mechanic was cause of death??
[QUOTE]
That could be it too.
to answer your questions
You may not feel the difference b/t 9.5:1 and 10:1.
Old Feb 9, 2003 | 08:33 PM
_Endless_'s Avatar
how can a mechanic cause it? i don't get it. i was also thinking that the fmu cause it.
so there's a chance of feeling the difference between 9.5 and 10.2:1 compression, i guess i'll go with the stock pistons again with compression ratio of 10.2:1 so i don't have to worry about future buyer from noticing the difference should i sell the car.
what do you think? anymore?
Old Feb 9, 2003 | 08:54 PM
I Like Boost's Avatar
it wouldnt really matter between the two comp. ratios, if you plan on selling it get whatever is cheaper, both will be fine at 9psi with "the hack"
Old Feb 9, 2003 | 10:14 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: compression ratio questions (IMPULSE B18C-T)
10.0 and 10.2 are going to be almost the same. dont waste your money lowering the compression 2 points. tune it properly and it should be fine.
Old Feb 15, 2003 | 01:29 PM
It could very well be the mechanics fault if he did not properly tune the motor. I have gone through 3 motors already because I learned the hard way from a mechanic that didn't know anything about tuning.
Old Feb 15, 2003 | 02:13 PM
ion_four's Avatar
if you're cracking open the engine and swapping pistons, I'd get some forged ones (as it seems like you were implying otherwise) even if you think you can't afford them. You'll most likely end up killing the ring-lands on these, too and then be out MORE money. just my .02.
Old Feb 15, 2003 | 04:16 PM
Cyber ITR's Avatar
Default Re: compression ratio questions (ion_four)
if u going to sell it soon , just put standard pistons in
CivicDude2k4
18
Oct 8, 2006 09:13 PM
i20ar
Sep 17, 2005 12:48 PM
TehMoonRulz
May 16, 2005 01:15 PM
madcrossover
Dec 13, 2004 06:40 AM
genop
Sep 17, 2003 10:45 PM
