Compression Ratio Question
Old Oct 9, 2013 | 09:02 PM
PowderMonkey's Avatar
Default Compression Ratio Question
Hello everyone!
I am buying a 85 crx tomorrow and am going to be doing a complete over-haul.
I am a bit newer to Honda engine building and wanted to ask a question about building a B series Engine. I am interested in getting the best of all worlds which I know is probably impossible but I wanted your opinions. I am looking to do a Turbo build. My thoughts were a ITR Head (for obvious reasons) a B18 block (for larger displacement), B16 Crank (higher Revs), and maybe a custom set of Rods to bring the compression up to near the mid to like 8:1 - 8.5:1
Has this build been done? Any major flaws you can see? Any advice would be appreciated. Also If anyone knows what type or size rods would put me here that would be awesome!
P.S. I apologize if this sort of build has been brought up before. I personally couldn't find anything on it though.
Thanks for any input,
-Max
Old Oct 9, 2013 | 09:39 PM
Default Re: Compression Ratio Question
Ok, Never mind. >_> Had a brain fart when posting this. Please Ignore thread lol.
Old Oct 10, 2013 | 08:16 AM
Schister66's Avatar
Man U FTW
LS block, LS crank, VTEC head with ITR cams...done. Also, keep the compression above 9:1 at a minimum. Personally, i would aim for 10:1 with a built bottom end
Old Oct 10, 2013 | 08:49 AM
kyden's Avatar
getting a b18 block and putting a b16 crank in makes it a 1.6L still.
Old Oct 10, 2013 | 10:39 AM
Kyden- I made that realization right after posting thus the forget this thread comment.
Schister- My end goal is ~400 whp. at that power range is it really safe with the b-series to be near 10:1? I am taking my time with this project and am not in any rush so any info is good info
(also those stickies here in the forced induction area are suuuper helpfull, Honda-Tech is awesome!!)
Old Oct 10, 2013 | 11:01 AM
Schister66's Avatar
Man U FTW
The compression depends on your fuel. Here is a great thread to illustrate how awesome high compression turbo builds are....Muckman's build is one of my all-time favorites and when i build another Honda, it will follow this same mould
https://honda-tech.com/forums/forced-induction-16/muckman%92s-integra-high-compression-super-build-3086196/
Old Oct 10, 2013 | 02:08 PM
That thread has inspired me, i am definitely doint a high comp turbo setup. Do you think id be able to do the 85 crx build at atleast 400whp for less than 5500? Thats about the budget im worling with.
Old Oct 10, 2013 | 02:15 PM
jdmh22eg2's Avatar
i think it will be tight at 5500.
ROUGHLY fig this way.
legit real ITR head -$1k
built bottom end parts(no machining)--$850 ISH
tuning MINIMUM w/o tuning software ie: hondata so on-- $800
tuning software--$550 ISH
quality turbo $800 used
quality turbo mani-- $800
cams- $500 ISH
valve train-$400 ISH
block machine work-- $500 ISH (depending on what u want/have done
say another $1800 give or take a few hundred for misc parts.
Old Oct 10, 2013 | 02:18 PM
Oops sorry for double post. Phone is being dumb
Old Oct 11, 2013 | 09:07 AM
Schister66's Avatar
Man U FTW
$5500 is a good budget for a build. That affords you room to build the engine and piece together a name-brand turbo setup. Search the www.hondamarketplace.com for deals on used parts...there are a lot of setups that go unfinished and as such, there are a lot of new or barely used parts floating around
Old Oct 11, 2013 | 09:26 AM
mafia's Avatar
Your goal seems do able with your buget.
I'm at 420whp with go autoworks street kit with a race manifold
(from kaizen speed) made 400whp on the log that came with the kit.
I'm at 10cr with Ls crank, stock sleeves stock cast Gsr head with Itr cams.
carbondc2
16
Feb 28, 2013 03:56 PM
7rrivera7
Jan 25, 2010 06:45 PM
cubancrx
Nov 16, 2004 03:49 PM
Plan B
16
Apr 16, 2002 05:37 AM
