Compression calculating
Old Apr 27, 2004 | 07:39 PM
B18CRacer's Avatar
Default Compression calculating
Could I use this compression calculator to rely on accurate numbers.
http://www.corral.net/tech/compress.html
B18CRacer's Avatar
Default Re: Compression calculating (B18CRacer)
anyone know the numbers for the stock gsr?
Old Apr 27, 2004 | 07:49 PM
Kataku2K3's Avatar
I would actually just use C-Speed's as I know it's accurate. The only problem with it is it does not count in compression height (you can just adjust the piston to deck to compensate tho). A stock GSR is at 10.0:1. C-Speed Compression Calculator
4 door beast
Mar 21, 2012 05:20 AM
H2nr
Nov 12, 2004 09:45 AM
importboi22
Oct 7, 2003 05:19 PM
