Which Compression is the best Compression
Old Mar 28, 2002 | 07:39 PM
Hybridhonda10's Avatar
Default Which Compression is the best Compression
I was going to build a Hybrid Civic but me being 6'2" I scapped that idea in favor of a Tubro H22A 90-93 Accord. Anyways my quesion is this I plan to use JE Pistons but I am curious on what compression to get 9.0:1 or 10.0:1
Old Mar 28, 2002 | 07:47 PM
Malachi's Avatar
Default Re: Which Compression is the best Compression (Hybridhonda10)
im selling my accord, 1990 with 51000 original miles. haha, well good luck with your swap and the turbo. Ive read its actually pretty straight forward into the accord.
Old Mar 28, 2002 | 08:05 PM
98civicEX's Avatar
i'm 6'4", probably one of the tallest asians out there, an i own a boosted coupe!, can't beat it....
Old Mar 28, 2002 | 11:58 PM
DLB1994's Avatar
Default Re: Which Compression is the best Compression (98civicEX)
i ever seen a asian thats 6'4"
Old Mar 29, 2002 | 12:13 AM
Ray's Avatar
Ray
New User
Default Re: Which Compression is the best Compression (DLB1994)
Im asian, 6'2" too actually I have a friend that is 6'6"
Old Mar 29, 2002 | 04:18 AM
Dustorm's Avatar
go with the 9.0:1. Much safer if you are planning on boost.
Old Mar 29, 2002 | 05:00 AM
SIK IN DA HED's Avatar
New User
Default Re: Which Compression is the best Compression (Dustorm)
Old Apr 9, 2002 | 01:30 PM
-Racer X-
Guest
Posts: n/a
Default Re: Which Compression is the best Compression (dlplayboy)
um, id say like 8:1 for boost
Old Apr 9, 2002 | 01:37 PM
turbopanda's Avatar
Default Re: Which Compression is the best Compression (94hondahybrid)
i'd go somewhere between 8-9:1 -- leaning more towards the 8 side, especially if you're gonna be pushing crazy boost
Old Apr 9, 2002 | 03:58 PM
bigTom's Avatar
Default Re: Which Compression is the best Compression (nathan's boosted civic)
8.8 JE piston, Eagle Rod!
Old Apr 9, 2002 | 04:26 PM
jamal-188's Avatar
Default Re: Which Compression is the best Compression (ek9t)
I'm surprised it took this long for somebody to mention this setup
Old Apr 9, 2002 | 04:47 PM
VTC_CiViC's Avatar
Default Re: Which Compression is the best Compression (jamal-188)
Alright dammit, I give in! I wasn't around the day this came up, so for god's sake what isit!?
Old Apr 9, 2002 | 07:37 PM
Prelude Vtec 23's Avatar
I would like to know also, I just sent my block out to get resleeved and bored out, im putting a turbo on and I was planning to get 8:1 arias pistons now I have 2nd thoughts after reading this thread. Someone please explain which is better and why, and pros and cons!!
Old Apr 9, 2002 | 11:54 PM
New User
Personally im 6'2" and have more than enough room in my civic hatch. (enough room for me and my girlfriend to be in one seat if you know what I mean)
hAHAHAHAHhahahahHAHAHAHAH
Old Apr 10, 2002 | 01:22 AM
BlackGSR's Avatar
8:1 is extremely low ... especially for a 1.8 liter engine. I even think 9:1 is low. I'm shooting for 9.8:1 with my engine.
Old Apr 10, 2002 | 09:01 AM
downpipe's Avatar
Old Apr 10, 2002 | 09:11 AM
downpipe's Avatar
Default Re: Which Compression is the best Compression (VTC_CiViC)
it was in someone's signature...the whole post was written in broken english and it just became a joke about the guy having only one rod and piston. reading the whole thing unfolding was funny...it tied in to a few other posts...i think even the one about the guy who blew his motor running his greddy turbo without hooking up the blue box. it still makes me chuckle.
Old Apr 10, 2002 | 09:25 AM
VTC_CiViC's Avatar
Default Re: Which Compression is the best Compression (downpipe)
Whew! Thank you!
Old Apr 10, 2002 | 06:22 PM
downpipe's Avatar
no problem.
Old Apr 10, 2002 | 08:42 PM
racerxadam's Avatar
Default Re: Which Compression is the best Compression (Prelude Vtec 23)
with a lower compression ratio you get a larger tuning window which means your tuning doesn't have to be as well done and you gain the ability to run higher boost. with a higher compression ratio the turbo will spool faster and you don't have to run as much boost to get the same power.
Old Apr 10, 2002 | 09:16 PM
Default Re: Which Compression is the best Compression (racerxadam)
In your opinion what do you think is better than. 8:1 or 9:1
Old Apr 11, 2002 | 05:49 AM
X2BOARD's Avatar
9.0:1 will allow a quicker spool time than lower CR's. It will provide acceptable low end tq (pfft ) and accept med to high boost pressures.
At 8.0:1, you can run crazy boost pressures, allowing overall higher Hp if your turbo can keep up and you have the fuel/spark to do it. But at 8.0:1, the car will be a pig on the street unless you are in boost.
Old Apr 11, 2002 | 07:44 AM
TurboDANDEE's Avatar
Default Re: Which Compression is the best Compression (X2BOARD)
what's wrong with yall?! why are yall scared to go high compression? im personally going atleast 10.1:1 to create alot more power and quicker spool time. its proven fact that high compression and turbo go well together. im sure SERIOUS racers here will back me up, forget low compression and turbo lag, pull up to a high compressioned turbo car and you will get smoked.
Old Apr 11, 2002 | 08:02 AM
internet ay's Avatar
Default Re: Which Compression is the best Compression (JiSATSU RaceR)
Old Apr 11, 2002 | 09:00 AM
Agamemnon's Avatar
New User
Ask any racer, any real racer....
