compression
Old Sep 28, 2002 | 10:16 AM
See Are X's Avatar
Default compression
I just did a compression test on my 92 B18A, and I got
195 195 185 200
are these good enough numbers for forced induction?
also, when doing a compression test does it matter if the enging is warm or cold? and does it matter how long you crank the enging?
Old Sep 28, 2002 | 10:23 AM
b18bturbo's Avatar
Default Re: compression (See Are X)
195 195 185 200
To your question yes it matter if the negine is cold or hot. Try to do the compression on a motor thats avg heat temp. cranking also effect how the compression is.
IF you keep both consistent then you dont have nothing to worry about. By the numbers everything looks good.
Old Sep 28, 2002 | 12:43 PM
filetofit
Guest
Posts: n/a
Those are damn good numbers for a b18a that old.
self_made
Jun 19, 2005 12:36 PM
Mr.Integra
Apr 22, 2004 07:55 PM
builtprelude
Jan 22, 2004 10:49 PM
