comp turbo and pro1 cams?
Old Aug 16, 2011 | 08:16 PM
bzyq2001's Avatar
Default comp turbo and pro1 cams?
i have ct4 compturbo on BB, turbine wheel it is 64in and 74ex, housing is divided t4 ar .70,
will this combo will flow enough for skun2 pro1 cams?
i have p&p head
and is this orignal design of comp turbo or copy of garrett or BW (it has 10blades)
Old Aug 16, 2011 | 09:37 PM
TheShodan's Avatar
Moderator
Default Re: comp turbo and pro1 cams?
Comp turbo is a copy of itself. They don't copy Garrett or BW successfully, they tend to copy Forced Performance turbos.
Old Aug 17, 2011 | 02:01 PM
bzyq2001's Avatar
ok, thx
anybody has idea that this housing will be good with pro1 cams?
it's 84mm b18c, max 30psi
Old Aug 18, 2011 | 01:18 AM
bzyq2001's Avatar
it's look like it's p-trim but with 10blades
64.6mm in, 74,4mm ex
Old Aug 18, 2011 | 08:51 AM
civic-r11's Avatar
Local shop.. Is using the triple bearing version.. On a stock bored.. Sleeved.. Ls vtec.. With pro 1.. - and made 703 whp.. At 29 psi. Ran out of map sensor.. Gm map
Old Aug 18, 2011 | 01:34 PM
bzyq2001's Avatar
can u tell me what turbine and compressor combo with which turbin housing are u using?
can u show your dyno
fusion645
Sep 20, 2010 05:29 AM
sonne_side
Feb 4, 2009 08:35 PM
2LiterTurboSeR
Nov 11, 2005 03:26 PM
Overblown-Teg
Sep 12, 2003 04:57 PM
earl
Dec 17, 2001 05:17 AM
