comp. on built engine.
Old Jul 16, 2002 | 05:22 PM
integRated109's Avatar
Default comp. on built engine.
just wondering what the proper compression is for my car. its a sleeved(81mm) B18C5 with 9.5:1 JE pistons. i did a test today and came up with 165 across the board, a little less than i was use to on the stock engine. just want to make sure im in the range.
Old Jul 17, 2002 | 09:06 PM
Default Re: comp. on built engine. (integRated109)
Old Jul 17, 2002 | 09:16 PM
AGen2integra's Avatar
http://www.speed-factor.com ...... Nice intro, what kind of BOV is that?
Old Jul 17, 2002 | 09:33 PM
Default Re: comp. on built engine. (AGen2integra)
sites still under construction, our pres started to rebuild it, and then got a whole bunch of wierd cars to turbo so hes been really busy. im not totally sure what car he used for the BOV, sounds like our TSI, with the stock DSM one on there. thanks for checking it out, it will be up pretty soon, with pics of all the custom manifolds and setups weve worked on.
Old Jul 17, 2002 | 11:07 PM
boostaholic's Avatar
For 9.5:1, that's kinda low for compression numbers. Was the motor warm when you did the test?
Old Jul 18, 2002 | 09:33 PM
Default Re: comp. on built engine. (boostaholic)
now that i think about it, no it wasnt, it had been sitting all night because it wouldnt idle at all. have to check again tomorrow.
Old Jul 18, 2002 | 09:48 PM
Flamenco-T's Avatar
yeah, I was about to say, I used to get 215-220 with 10:1 CR
I am on 9.8:1 now, wonder what the CR is going to be...
Old Jul 18, 2002 | 11:02 PM
W.Zero's Avatar
that sounds about right cause im 9:1 arias and my reads i think 145 last i remember.
Old Aug 5, 2002 | 12:24 PM
AVATAR's Avatar
I have 9:1 and I got 185 all across the board. . .?
Old Aug 5, 2002 | 01:41 PM
fast[R]'s Avatar
Default Re: comp. on built engine. (AVATAR)
I also have 9:1 and got 165 across the board, I guese gauges read diferent, its ok if they are all the same
AnAccordIsForever
Nov 4, 2006 02:20 PM
OnePointFive
May 4, 2006 12:29 PM
toooslow
Jun 26, 2003 05:35 PM
shamoo
Sep 25, 2002 02:53 PM
mugenracer
May 21, 2002 02:35 PM
